  1. Hi
    Is there any way to batch merge using mkvmerge? I want to select parts by file order like this script
    for %%a in ("*.mkv") do "C:\Program Files\MKVToolNix\mkvmerge.exe" -o "muxed.mkv" "first-file-in-folder" + "2nd-file-in-folder" + "3rd-file-in-folder"
    pause
    Apr 2015
    Argentina
    Like this?
    @echo off
    set /p video=video format:
    set /p audio=audio format:
    set /p sub=subtitle format:
    for %%a in ("*.%video%") do "C:/Program Files/MKVToolNix\mkvmerge.exe" --output ^"Output_folder/%%~na.mkv^" --language 0:und --compression 0:none ^"^(^" ^"%%~na.%video%^" ^"^)^" --language 0:und --compression 0:none ^"^(^" ^"%%~na.%audio%^" ^"^)^" --sub-charset 0:UTF-8 --language 0:und --compression 0:none ^"^(^" ^"%%~na.%sub%^" ^"^)^" --track-order 0:0,1:0,2:0
    pause
    Only that video, audio and subtitle must have the same name, also only allows multiplexing of each file, cannot create a mkv with multiple audio.
    Sorry for my English, i use a translator.
  3. Originally Posted by arielacade View Post
    Like this?
    @echo off
    pause
    Thanks arielacade
    But i need to append multiple .mkv files with names like this
    1-001.mkv
    1-002.mkv
    1-003.mkv
    1-004.mkv
