I cut/pasted a few 3gp files from my phone to my pc using a usb cable. The transfer seemed to go just fine except that when I tried playing the videos in my computer the first one was around a minute and a half long but it stops playing at 4 seconds. Also, the file size is only 12mb which would be too small for a minute and a half video. All of the other videos that were transferred work perfectly. I don't know if the file was damaged before transferring because I never played it on my phone. Could the transfer itself damage the file? and is there any way to recover it?
	If it's content that you feel comfortable sharing, and it doesn't violate forum rules, just attach it here using the Upload files/Manage attachments button underneath the post text entry form and someone can take a look.
 I believe Windows is supposed to do a CRC to ensure all file transfers complete successfully. If that is correct, the file you have should match what was stored on the phone.
 https://askleo.com/how_do_i_fix_a_cyclic_redundancy_check_error_when_i_try_to_copy_a_file/
	Thank you for the reply but unfortunately I can't share this video. Here is what I got from mediainfo:
 Code:General Complete name : C:\Users\David\Desktop\New folder\20161008_785213589.3gp Format : MPEG-4 Format profile : Base Media / Version 2 Codec ID : mp42 (isom/mp42) File size : 12.5 MiB Duration : 1 min 31 s Overall bit rate : 1 145 kb/s Encoded date : UTC 2016-10-08 16:45:03 Tagged date : UTC 2016-10-08 16:45:03 com.android.version : 6.0.1 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4 Format settings, CABAC : Yes Format settings, ReFrames : 1 frame Format settings, GOP : M=1, N=30 Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 4 s 765 ms Source duration : 4 s 768 ms Bit rate : 17.0 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Variable Frame rate : 30.000 FPS Minimum frame rate : 27.616 FPS Maximum frame rate : 30.120 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.273 Stream size : 9.65 MiB (77%) Source stream size : 9.65 MiB (77%) Title : VideoHandle Language : English Encoded date : UTC 2016-10-08 16:45:03 Tagged date : UTC 2016-10-08 16:45:03 mdhd_Duration : 4765 Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 1 min 31 s Bit rate mode : Constant Bit rate : 256 kb/s Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 kHz Frame rate : 46.875 FPS (1024 spf) Compression mode : Lossy Stream size : 2.78 MiB (22%) Title : SoundHandle Language : English Encoded date : UTC 2016-10-08 16:45:03 Tagged date : UTC 2016-10-08 16:45:03
	The video is indeed too small to be 91 secs long.
 Maybe you could attempt to use some recovery software to undelete the file on your phone, if you haven't written to your phone's storage much in the past two days.
  Canon HG20 AVCHD video file transfer to Win 7 machineBy MykRian in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 8Last Post: 11th Nov 2013, 18:14
  Looking for a Damaged AVI FileBy Ancalagon in forum Newbie / General discussionsReplies: 0Last Post: 23rd Apr 2013, 07:05
  Fixing damaged mts fileBy Wakey82 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Nov 2012, 01:44
  Corrupted/damaged video file .aviBy aizen in forum RestorationReplies: 8Last Post: 31st Jan 2012, 14:17
  HELP! Damaged/Corrupted MOV file.By neil wilkes in forum EditingReplies: 3Last Post: 13th Nov 2011, 08:09
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
