I record tv shows. The old format is MPEG2 video + AC3 audio in a .TS container. I would run mpeg2repair just to log errors on those files, and it would show if there were video or audio timestamp problems, etc. However, the new format is AVC video + AC3 audio in a .TS container, so mpeg2repair is useless. Is there any software out there that can check this stream for errors? I've been using this command line with ffprobe for now:
In the errors.txt file I often find things likeCode:ffprobe.exe -show_frames -print_format csv -i "FOLDER\FILE.ts" > "FOLDER\probe.csv" 2>> "FOLDER\errors.txt"
I'm not sure what to make of any of it. Do any of these errors actually affect the viewing of the video (like screen tearing, macroblocking, other obvious visible glitches)? What does [h264 @ 0000000004152980] mean? I haven't seen any audio errors yet, but I presume that they would appear there too.Code:[h264 @ 000000000409baa0] Found reference and non-reference fields in the same frame, which is not implemented. Update your FFmpeg version to the newest one from Git. If the problem still occurs, it means that your file has a feature which has not been implemented. [h264 @ 000000000409baa0] If you want to help, upload a sample of this file to ftp://upload.ffmpeg.org/MPlayer/incoming/ and contact the ffmpeg-devel mailing list. [h264 @ 000000000409baa0] decode_slice_header error [h264 @ 000000000409c380] reference picture missing during reorder [h264 @ 000000000409c380] Missing reference picture, default is 65549 [h264 @ 0000000000374b20] reference picture missing during reorder [h264 @ 0000000000374b20] Missing reference picture, default is 65556 [h264 @ 0000000004152980] reference picture missing during reorder [h264 @ 0000000004152980] Missing reference picture, default is 65564 [h264 @ 0000000004153280] mmco: unref short failure [mpegts @ 0000000000380380] PES packet size mismatch [h264 @ 00000000003a5440] missing picture in access unit with size 170 [h264 @ 000000000409baa0] no frame!
Have you tried view the video that shows such errors? Do you notice anything?
But I haven't seen anything easy like mpeg2repair for avc video ts streams.
WMV files with errors: How to check + cut out bad frames, possible?
By DRP in forum Video ConversionReplies: 9Last Post: 11th May 2016, 20:33 -
Any software to check all the info of any video
By kenny1999 in forum Newbie / General discussionsReplies: 1Last Post: 12th Jan 2016, 15:12 -
Is there software to scan a full video file to check if it's OK?
By tbird2340 in forum Newbie / General discussionsReplies: 3Last Post: 27th Jan 2013, 16:17 -
web server software to stream video to members - needgood software package!
By tuprox in forum Video Streaming DownloadingReplies: 1Last Post: 26th Dec 2012, 21:34 -
Searching Command-LIne Utility to check video file for some errors...
By steveallen in forum Newbie / General discussionsReplies: 0Last Post: 25th Aug 2012, 07:40
