Trying to setup a format like the one used in this video using CyberLink PowerDirector 15 (64-bit). I can't even get close to the size of this video using the same video to encode.
General
Complete name : D:\AANew\seen\Candy.mp4
Format : MPEG-4
Format profile : Base Media
Codec ID : isom (isom/iso2/avc1/mp41)
File size : 19.0 MiB
Duration : 10 min 48 s
Overall bit rate : 245 kb/s
Writing application : Lavf57.25.100
Video
Format : AVC
Format profile : High@L3.2
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : avc1
Bit rate : 110 kb/s
Width : 320 pixels
Height : 240 pixels
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 25.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.057
Stream size : 8.51 MiB (45%)
Writing library : x264 core 148 r2665 a01e339
Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=7 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=0 / keyint=90 / keyint_min=9 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=crf / mbtree=1 / crf=26.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=400 / vbv_bufsize=2400 / crf_max=0.0 / nal_hrd=none / filler=0 / ip_ratio=1.40 / aq=1:1.00
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration_LastFrame : 46 ms
Bit rate mode : Constant
Bit rate : 128 kb/s
Channel(s) : 2 channels
Sampling rate : 44.1 kHz
Frame rate : 43.066 FPS (1024 spf)
Compression mode : Lossy
Stream size : 9.92 MiB (52%)
Default : Yes
Alternate group : 1
Well the only thing that affects video size where the run length is the same is the bitrate of the video + audio.
Now if Power Director will not allow you to create a video with such a low bitrate then you will not get close.
Which Format is Better or the Same (MPG vs AVI) when Burned Back to MPEG-2
By victor43 in forum DVD RippingReplies: 9Last Post: 17th Aug 2016, 12:57 -
Take 480p or 1080p MPEG-4s to a DVD format with little or no loss?
By fdecker in forum Authoring (Blu-ray)Replies: 4Last Post: 15th Oct 2014, 18:11 -
Any good software for conversion from avi /mp4 /wmv to the Mpeg-2 format?
By seymoria in forum Video ConversionReplies: 3Last Post: 10th Feb 2014, 16:57 -
Recommended MPEG Streamclip settings for export to FCPX-friendly format?
By thetallest in forum MacReplies: 2Last Post: 5th Jun 2013, 15:44 -
Encode MPEG-4 to DVD Format Without Doubling File Size
By JustAnotherUsername in forum Authoring (DVD)Replies: 1Last Post: 6th Feb 2012, 23:10
