i read from hauppauge discussions that hd pvr 1 & 2 has the decompressed preview window by the graphics card. i assume startech usb 3.0 is also. i tried vdub decompressor & it doesnt seem not even half the same the way the graphics card displays the decompressed output. i wont post any examples. can this be done without using fraps?
Huh? The StarTech USB3HDCAP is natively uncompressed, so the preview doesn't require decompression in the way that Hauppauge's hardware compression devices do.
is it still somewhat decompressed? why does the startech preview appear more crisp/sharp than the captured mp4 that has more artifacts (less sharp). that seems similar to the hd pvrs except the pvrs preview are lower quality, which still appear good in my opinion compared to the captured mp4.
That's like describing something as "somewhat perfect" or "somewhat dead".
The StarTech uses software compression. The preview is uncompressed. Your captured MP4 is a lossy-compressed version of this uncompressed data. If you care to, you can capture with a lossless compressor, if you have a fast enough and big enough hard drive. The video quality will then be identical to the preview.why does the startech preview appear more crisp/sharp than the captured mp4 that has more artifacts (less sharp).
Raise the bitrate, capture with a more efficient H.264 compressor like x264vfw instead of StarTech's own software, or capture lossless and compress to H.264 as a final stage in slower-than-realtime for better quality at the same bitrate.the pvrs preview are lower quality, which still appear good in my opinion compared to the captured mp4.
Why is my StarTech capture so funky?
By JVRaines in forum Capturing and VCRReplies: 24Last Post: 12th Jul 2016, 01:13 -
How do I set preview window size in VirtualDub?
By paulot in forum Newbie / General discussionsReplies: 5Last Post: 30th Mar 2015, 17:36 -
.TS video slowing down in a preview window, but fine on the timeline
By Mayx in forum Newbie / General discussionsReplies: 5Last Post: 1st Aug 2014, 00:50 -
Sony Vegas 11 playing very slow x264 videos format in the preview window
By gil900 in forum EditingReplies: 4Last Post: 1st Mar 2013, 12:28 -
pinnacle 16 - displaying circle arrow in preview window
By adom in forum EditingReplies: 2Last Post: 13th Feb 2013, 16:33
