    Oct 2016
    Bulgaria
    Hello videohelp community,
    I am currently trying to capture a video from
    huntersvideo.com
    http://en.huntersvideo.tv/movie/fox-calling-1/316218
    PS: Will provide credentials if needed.
    Finding the link to the m3u8 file for the 1080 version was not a problem.
    http://cfvod.kaltura.com/fpshls/p/2122821/sp/212282100/serveFlavor/entryId/0_axtbseg6/v/2/flavorId/0_vac5szwj/name/a.mp4/index.m3u8
    I also found the link to the manifest file.
    http://cdnapi.kaltura.com/p/2122821/sp/212282100/playManifest/entryId/0_axtbseg6/format/mpegdash/tags/dash/protocol/http/f/a.mpd
    The only file I managed to download was the DRM protected .wvm which is not playable.
    http://cdnapi.kaltura.com/p/2122821/sp/212282100/playManifest/entryId/0_axtbseg6/format/url/tags/widevine/protocol/http/f/a.wvm
    I also tried to capture the video with ffmpeg but got the error
    Sample-aes encryption is not supported yet.
    Adownloader doesn't seem to work either. It captures the .ts fragments but fails to convert them into something playable and shows me "No such file" at the end.
    Apperently I am doing something wrong. Any help will be appreciated.
  2. Member Emeritus
    May 2014
    You can download the low quality version. The higher qualities all seem to have DRM.
    http://cdnbakmi.kaltura.com/p/2122821/sp/212282100/flvclipper/entry_id/0_axtbseg6/version/0/a.mp4?novar=0
    Oct 2016
    Bulgaria
    Thanks for your reply, ponens. This is still better than nothing. You helped me a lot!
    However, is there a way to avoid/work around this DRM protection or the only way is with a screen recorder?
    Edit: Inside the m3u8 file there is a link to the Key file if this can help. I noticed that the key changes after each download, so my guess is that it expires after a certain amount of time.
    Oct 2016
    Bulgaria
    Any possibility to download it with ism downloader?
    I found the link to the .ism file
    http://cdnapi.kaltura.com/p/2122821/sp/212282100/playManifest/entryId/0_axtbseg6/format/sl/tags/mbr/protocol/http/f/a.ism
    Still looking for solution, please help.
  5. Anonymous84347344
    Guest
    I didn't tried it.
    This file contains some Base64 encoded data.
    <WRMHEADER xmlns="http://schemas.microsoft.com/DRM/2007/03/PlayReadyHeader" version="4.0.0.0"><DATA><PROTECTINFO><KEYLEN>16</KEYLEN><ALGID>AESCTR</ALGID></PROTECTINFO><KID>9ezRFIa0rLyJd7rG9/+z8A==</KID><CHECKSUM>Fi7eLct8MgE=</CHECKSUM><LA_URL>https://udrm.kaltura.com/playready/license</LA_URL><LUI_URL>http://www.kaltura.com</LUI_URL></DATA></WRMHEADER>
