Results 1 to 13 of 13
  1. Hi! I need help to extract closed capton of video from google drive from this URL: https://drive.google.com/file/d/0BxX0Rrs7OMffZC1WR0o0enh6ZkE
    I tried to extract with Google2SRT but it didn't work. Any suggestion would be appriciate.
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    I will start by saying that I've not used Google drive. But I thought that it is only a data storage service. If so, then you aren't extracting closed caption "from google drive", you are simply trying to extract them from a file stored on Google drive.
    Step 1: download the file to your PC
    Then the tool needed to proceed may vary based on the file type or may not be possible at all. Most files (at least ALL of the files I've ever used) do not contain "closed captions". Some may have subtitles. But again, based on the file type, you may or may not be able to extract them.
    I've only even seen closed captions on DVD's.
    Google is your Friend
    Aug 2006
    I have seen closed captions in video files that were implemented just like NTSC DVD and N. American broadcast TV closed captions, although I don't think the chances of that being true in this case are good. I could use CCExtractorGUI to extract them.
  4. If you still don't extract subtitle
    this the SRT file
  5. Originally Posted by roma_turok View Post
    this the SRT file
    Please tell me how you managed to do this !!!
  6. Originally Posted by RaphaKoyun View Post
    this the SRT file
    I need sample link video to explain
    the original link don't work anymore
    do you have sample?
  7. Originally Posted by roma_turok View Post
    this the SRT file
    do you have sample?
    https://drive.google.com/file/d/0B60I5fOgzgbBNmhTalQtR21SUW8/view
  8. I would like to know ALL types of video files (AND streaming videos) that contain subtitles (or closed captions) and in each case what kind of software is needed to extract the subtitle (closed captions). For starters, here is a PBS TV video file recorded with $30 Walmart digital recorder.
    These video files almost always have closed captions and can be extracted to srt with CCextractor. Often you have to make a simple adjustment to the subtitle timing, but the adjustment will hold the timing correctly through the whole show. Note: my version of vlc (2.2.4) will not play the ts video with the srt file. Media Player Classic Home Cinema works fine. The attached srt file is adjusted for better timing. I used Time Adjuster for this.
  9. Open video in Google Chrome
    right click and select Inspect
    go to Network
    in Filter type timedtext
    right click and select Open in new tab:
    [Attachment 42415 - Click to enlarge]
    save to XML file:
    [Attachment 42418 - Click to enlarge]
    Open XML in Subtitle Edit and save as SRT:
    [Attachment 42417 - Click to enlarge]
  10. Open video (https://drive.google.com/file/d/0B60I5fOgzgbBNmhTalQtR21SUW8/view) in Google Chrome
    go to Network
    Thank you for the clear directions with screenshots. I was able to download the srt subtitle file.
  11. Originally Posted by roma_turok View Post
    go to Network
    save to XML file:
    I will pray for you until the end of your life!
    Thank you!
    It worked! I do not believe!
    Thank you very very very much!
  12. Originally Posted by roma_turok View Post
    go to Network
    save to XML file:
    I found the way to do this for hours. I saw this thread. I saw you. I tried. I registered. Now I thank you.
  13. Originally Posted by Krispy Kritter View Post
    You have to know that Google Drive also allows you to watch online any videos that are stored in it, besides uploading and downloading them, with the possibility of adding closed captions to any videos that you upload to the page (it even allows you to turn on and off closed captions, select video resolution and watch the video with exactly the same interface as YouTube). But, unlike what happens with videos, Google Drive doesn't offer directly an option to download closed captions that appear with a video.
