ok, so all of a sudden lots of files that are not out of sync before I encode them are now ending up out of sync. below is log to one file that is ending up out of sync, even stuff I have previously encoded with avstodvd is doing the same. I have tried reinstalling avstodvd, reinstalled lavfilters etc, help needed
<10/4/2016 10:38:21 PM>
START PROCESS
PROJECT SETTINGS
DVD Video Standard: NTSC
DVD Titles number: 1
DVD Size: 3195/4450 MB (72%)
DVD Output Setup: ISO UDF Image
DVD Label: DVD
DVD Menu: Motion Menu
Output Folder: C:\Users\blood\Videos
Delete Temp Assets Files: Yes
Delete Temp Working Files: Yes
Edit Command Parameters: No
Post Process Task: Show Progress Status window
PREFERENCES
MultiThread: 1
AVS Video Source Filter: A2DSource
AVS Audio Source Filter: A2DSource
AVS UpSize/DownSize Filter: Lanczos4Resize/Spline16Resize
Frame Adjust Strategy: 0
FPS Hard Conversion: 0
PAL SpeedUp: 0
NTSC SlowDown: 0
Video Resolution: 0
Video Encoder: 3
Video BitRate Min: 4500
Video BitRate Max: 5000
Keep DVD Compliant Video: 1
AC3 Audio Encoder: 0
Force FFmpeg for Long Audio: 1
DVD Audio Format: 0
DVD Audio BitRate: 384
Keep DVD Compliant Audio: 1
Normalize Audio: 0
Auto Delay Audio: 0
DVD Audio Language (Primary): EN - English
DVD Audio Language (Secondary): EN - English
DVD Subs Language (Primary): EN - English
DVD Subs Language (Secondary): EN - English
DVD Subs Font: Tahoma 16pt (255,255,255)
Chapters Interval: 5
Use Source Chapters: 1
DVD Burning Drive: E: HL-DT-ST DVDRAM GH24NSD0 LH00
DVD Burning Speed: 4x
Auto Erase DVD RW: 1
Execute with Elevated Privileges: 0
Unload ActiveMovie Library: 1
Adjust DirectShow Filters at runtime: 1
Save General Settings: 1
SYSTEM INFO
Processor Name: Intel(R) Core(TM) i3-3220 CPU @ 3.30GHz
Operating System: Windows 10 (10.0.14393) 64 bit
User has Admin Rights: YES
Running with Elevated Privileges: NO (3)
Available Output Disc Space: 107 GB
AviSynth is installed: YES (release 2.6.0)
LAV Filters is installed: YES (release 0.68.0)
ffdshow is installed: NO
CODECS REPORT
H.264/AVC: Microsoft DTV-DVD Video Decoder {212690FB-83E5-4526-8FD7-74478B7939CD}
Xvid: Mpeg4s Decoder DMO {2A11BAE2-FE6E-4249-864B-9E9ED6E8DBC2}
DivX 4/5/6: Mpeg4s Decoder DMO {2A11BAE2-FE6E-4249-864B-9E9ED6E8DBC2}
Other MPG4: Mpeg4s Decoder DMO {2A11BAE2-FE6E-4249-864B-9E9ED6E8DBC2}
DV: DV Video Decoder {B1B77C00-C3E4-11cf-AF79-00AA00B67A42}
MPEG1: MPEG Video Codec {feb50740-7bef-11ce-9bd9-0000e202599c}
MPEG2: Microsoft DTV-DVD Video Decoder {212690FB-83E5-4526-8FD7-74478B7939CD}
MP2: Microsoft DTV-DVD Audio Decoder {E1F1A0B8-BEEE-490D-BA7C-066C40B5E2B9}
MP3: MP3 Decoder DMO {BBEEA841-0A63-4F52-A7AB-A9B3A84ED38A}
AAC: Microsoft DTV-DVD Audio Decoder {E1F1A0B8-BEEE-490D-BA7C-066C40B5E2B9}
AC3: LAV Audio Decoder {E8E73B6B-4CB3-44A4-BE99-4F7BCB96E491}
TITLE 1 SOURCE FILES
Video: C:\Users\blood\Downloads\alt.binaries.mom\
Info: AVC - 4507 kbps - 1916x796 - DAR 2.407 - 23.976 fps (CFR) - Progressive - 1:20:55 hours - 116408 frames
Audio 1: C:\Users\blood\Downloads\alt.binaries.mom\
Info: AC3 - 384 kbps - CBR - 6 ch - 48000 Hz - 1:20:55 hours (0 ms delay) - EN
[MediaInfoLib - v0.7.77]
AVISYNTH SCRIPT
Import("C:\Program Files (x86)\AVStoDVD\Lib\A2DSource.avsi")
LoadPlugin("C:\Program Files (x86)\AVStoDVD\Lib\ColorMatrix.dll")
Video = A2DVideoSource("C:\Users\blood\Downloads\alt.binar ies.mom\, CacheFolder="C:\Users\blood\AppData\Local\Temp", VFR=false, FrameRateNum=2997, FrameRateDen=125, FrameRate=23.976)
# Audio is frameserved by AviSynth just for Preview and Edit purposes.
Audio = A2DAudioSource("C:\Users\blood\Downloads\alt.binar ies.mom\.mkv", CacheFolder="C:\Users\blood\AppData\Local\Temp")
Video = Video.ColorMatrix(source=0,dest=2)
Video = Video.ConvertToYV12()
Video = Video.AddBorders(0,140,0,142)
Video = Video.Spline16Resize(720,480)
#PullDown: using DGPulldown/HCenc to upsize FPS
AudioDub(Video, Audio)
DIRECTSHOW AUDIO MIXER OPERATIONS:
No LAV Filters mixer ON/OFF adjustment required at runtime
START VIDEO ENCODING OPERATIONS
Video Encoding Profile: HCenc VBR 2-pass
Target Video FileSize: 2893.8 MB
Encoding Parameters: -ini "C:\Users\blood\AppData\Local\Temp\DVD_1_.HCenc.in i"
HCenc ini file:
*INFILE C:\Users\blood\AppData\Local\Temp\DVD_1.avs
*AVSRELOAD
*OUTFILE C:\Users\blood\Videos\DVD_1_.m2v
*LOGFILE C:\Users\blood\AppData\Local\Temp\DVD_1_.HCenc.log
*MAXBITRATE 9000
*BITRATE 5000
*PROFILE BEST
*ASPECT 16:9
*PROGRESSIVE
*TFF
*PULLDOWN
*BIAS 50
*DC_PREC 9
*MATRIX MPEG
*AQ 1
*LUMGAIN 1
*SMP
*PRIORITY NORMAL
*DBPATH C:\Users\blood\AppData\Local\Temp
*WAIT 2
<10/4/2016 11:52:07 PM>
END VIDEO ENCODING OPERATIONS
Video Source Filter: A2DSource (DirectShowSource)
Created File: C:\Users\blood\Videos\DVD_1_.m2v (2886 MB)
OUTPUT VIDEO INFO: MPEG-2 Video - 4986 kbps - 720x480 - DAR 16:9 - 23.976 fps - Progressive (2:3 Pulldown) - 1:20:55 hours - 145508 frames
START AUDIO DEMUXING OPERATIONS (Track 1)
FFmpeg Parameters: -i "C:\Users\blood\Downloads\alt.binaries.mom\..m kv" -c:a copy -vn -sn -y "C:\Users\blood\Videos\DVD_1_.ToFix.ac3"
<10/4/2016 11:52:34 PM>
START AC3 FIXING OPERATIONS (Track 1)
ac3fix Parameters: "C:\Users\blood\Videos\DVD_1_
_1.ToFix.ac3" "C:\Users\blood\Videos\DVD_1_
_1.ac3"
<10/4/2016 11:53:07 PM>
END AUDIO DEMUXING OPERATIONS (Track 1)
Created File: C:\Users\blood\Videos\DVD_1__1.ac3 (222.3 MB)
OUTPUT AUDIO INFO: AC3 - 384 kbps - CBR - 6 ch - 48000 Hz - 1:20:55 hours (0 ms delay)
DVD CHAPTERS CREATION OPERATIONS
Title 1 Input Chapters List: 14409 30377 43444 58909 72839 84467 100555 109810
Title 1 Output Chapters List: 18011 37971 54304 73636 91048 105583 125693 137262
Created File: C:\Users\blood\Videos\DVD_1__Chapters.txt (61 Byte)
START DVD MENU BUILDING OPERATIONS
DVD Menu settings:
Style: 1
Aspect Ratio: 1
Titles Format: 1
Template: Blue Rain
Max Titles Page: 12
Enable Play All: 1
Force Play All: 0
Background Audio: 0
Max Thumbs Row: 4
Thumb Image Source: 0
Thumb Frame Position: 10%
HL Frame Format: 0
HL Selection Color: 5
HL Play Color: 0
Menu Video BitRate: 6000 kbps
Motion Menu Duration: 15 seconds
Thumb Drop Shadow: 2
Play All Shadow: 2
Arrows Shadow: 0
<10/4/2016 11:53:43 PM>
END DVD MENU BUILDING OPERATIONS
Created File (Menu Page 1): C:\Users\blood\Videos\DVD_1_MenuPage1.m2v (10.7 MB)
START DVD AUTHORING OPERATIONS
BatchMux Parameters: -arglist "C:\Users\blood\AppData\Local\Temp\DVD_1_BatchMux. ini"
BatchMux ini file:
-bmlog "C:\Users\blood\AppData\Local\Temp\DVD_1_BatchMux. log"
-d "C:\Users\blood\Videos\DVD_1\VIDEO_TS"
-mxp "C:\Users\blood\AppData\Local\Temp\DVD_1_MuxMan.mx p"
-l "C:\Users\blood\AppData\Local\Temp\DVD_1_MuxMan.lo g"
-muxman "C:\Program Files (x86)\AVStoDVD\MuxMan"
-prio NORMAL
-palette "C:\Users\blood\AppData\Local\Temp\DVD_1_Palette.t xt"
-v "C:\Users\blood\Videos\DVD_1_.m2v"
-vidmode LB
-a1 "C:\Users\blood\Videos\DVD_1__1.ac3"
-a1lang en
-cellfr "C:\Users\blood\Videos\DVD_1__Chapters.txt"
-progfr "C:\Users\blood\Videos\DVD_1__Chapters.txt"
-chapfr "C:\Users\blood\Videos\DVD_1__Chapters.txt"
-SEG2v "C:\Users\blood\Videos\DVD_1_MenuPage1.m2v"
-SEG2vidmode LB
-SEG2s1 "C:\Users\blood\Videos\DVD_1_Menu.sst"
-SEG2s1dmode WIDE_LB
-SEG2hlmnu "C:\Users\blood\AppData\Local\Temp\DVD_1_MenuPage1 _Buttons.mnu"
-SEG2hlcsm "C:\Users\blood\AppData\Local\Temp\DVD_1_Highlight Scheme.csm
-hcn "C:\Users\blood\AppData\Local\Temp\DVD_1_BatchMux. hcn"
<10/4/2016 11:58:10 PM>
END DVD AUTHORING OPERATIONS
Created Folder: C:\Users\blood\Videos\DVD_1 (3184.1 MB)
CHECK DVD SIZE
DVD Folder (actual) Size: 3184.1 MB
vs Assets Size: 3118.9 MB -> OK
vs Estimated Size: 3195 MB -> 0.3% undersize
<10/4/2016 11:58:11 PM>
START ISO IMAGE BUILDING OPERATIONS
ImgBurn (ISO) Parameters: /mode isobuild /buildmode imagefile /src "C:\Users\blood\Videos\DVD_1\VIDEO_TS" /dest "C:\Users\blood\Videos\DVD_1.iso" /volumelabel "DVD" /filesystem "ISO9660 + UDF" /udfrevision "1.02" /overwrite yes /noimagedetails /start /close
<10/5/2016 12:00:59 AM>
END ISO IMAGE BUILDING OPERATIONS
Created File: C:\Users\blood\Videos\DVD_1.iso (3.1 GB)
<10/5/2016 12:01:00 AM>
AVStoDVD Project ended successfully.
Log file created by AVStoDVD Release 2.8.4
	I'm a bit of a Newbie, but I think your problem is that when you installed Windows 10, it changed all your Codec filters to Microsoft ones.
 I had the same problem.
 Best to download Win7DSFilter Tweaker. Then use this simple program to change all the Codec filters to LAV.
 Also make sure you do not have any other Codec filters on the computer.
 BTW, the latest LAV filters are now ver 0.68.1.
 Hope this helps.
	Microsoft has a habit of assuming only there software exists or is better than everybody else
 The problems, as suggested, is likely to be the codecs has been forced back to microsoft filters (which are rubbish)
 Update to the latest LAVFilters, and you will probably have to force the codecs to LAVFilters using Win7DSFilter Tweaker (I have to)
 This should fix out of sync audio, it did for me after much head banging and found out by accident the the codecs wasn't changing to LAVFilters after reinstalling and uninstaller and lost of frustration wondering why it worked fine previously but now not at all
 I also found out my 64-bit filters were also not set, so now all my filters are running via LAVFiliters with no more issues ....
  AVStoDVD audio out of sync on converted mkvBy whammoed in forum DVD RippingReplies: 23Last Post: 11th Jul 2014, 11:00
  AVStoDVD Audio not Sync'dBy nedriv49 in forum Video ConversionReplies: 12Last Post: 22nd Apr 2014, 14:03
  ...By jovopros in forum Authoring (DVD)Replies: 5Last Post: 7th May 2013, 02:55
  AVStoDVD creates VOBs with Audio sync problemsBy martinlest in forum AudioReplies: 3Last Post: 29th Apr 2013, 05:03
  Audio out of sync with avstodvdBy p1r473 in forum Newbie / General discussionsReplies: 11Last Post: 27th Jan 2013, 10:38
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
