Is there a 'good' video converter like Handbrake that can do 1440p and 2160p video encoding?
Also, I ran a (3 minute) video through Handbrake using Constant Quality close to loseless, and audio bitrate up, and yet the output file was only about 30MB more. Is that normal?
	HandBrake isn't inherently better or worse than other converters for this task. Either you are using it wrong or you are expecting things that can't happen. Provide input and output MediaInfo logs and if possible sample file. Tell us your settings and HandBrake version. Which video encoding level have you chosen? HandBrake will limit bitrate according to level so if the level is too low bitrate won't increase further even if you decrease CRF. What kind of source is it anyways? Hollywood movie, animation or Powerpoint slides? The type can change the outcome.
  Downsampling hi-res to 44.1 with nothing in higher frequencies. Any loss?By Killer3737 in forum AudioReplies: 22Last Post: 14th Apr 2015, 09:52
  Used Avidemux to edit video, resulted in 2x higher bitrate?By videoconverter11 in forum Newbie / General discussionsReplies: 9Last Post: 13th Feb 2015, 10:24
  Any point in watching higher res than 1080p on a 1080p monitor?By brassplyer in forum DVB / IPTVReplies: 4Last Post: 1st Dec 2013, 11:16
  1080p fraps avi + Handbrake = x1088 res?!?!?By duhmez in forum EditingReplies: 1Last Post: 29th Jul 2012, 07:00
  Why doesn't handbrake re-encode show video bitrate in MediaInfo?By KushSmoka420 in forum Video ConversionReplies: 3Last Post: 26th Mar 2012, 16:55
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
