Results 1 to 10 of 10
    Jun 2012
    New Zealand
    What do those here think is the best tool for removing ads?
    I have a .tts file recorded from TV and plan to convert to .mkv with Handbrake (unless this is a bad idea ?)
    The details from mediainfo are
    General
    Complete name : O:\Doubt_ The Scott Watson Case.tts
    Format : BDAV
    Format/Info : Blu-ray Video
    File size : 6.75 GiB
    Duration : 2 h 12 min
    Overall bit rate : 7 264 kb/s
    Maximum Overall bit rate : 28.0 Mb/s
    Video
    Menu ID : 1200 (0x4B0)
    Format : AVC
    Format profile : Main@L4
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Codec ID : 27
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 25.000 FPS
    Standard : Component
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan type, store method : Separated fields
    Scan order : Top Field First
    Color range : Limited
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio #1
    Format : AAC
    Format profile : HE-AAC / LC
    Muxing mode : LATM
    Codec ID : 17
    Bit rate mode : Variable
    Channel(s) : 2 channels
    Sampling rate : 48.0 kHz / 24.0 kHz
    Frame rate : 23.438 FPS (1024 spf)
    Compression mode : Lossy
    Delay relative to video : -400 ms
    Language : English
    Audio #2
    Format : AAC
    Muxing mode : LATM
    Codec ID : 17
    Delay relative to video : -440 ms
    Language : Italian
    Language, more info : Visual impaired commentary
    descriptor_tag_extension : 6
    Audio #3
    Format : AC-3
    Format/Info : Audio Coding 3
    Format settings, Endianness : Big
    Codec ID : 129
    Bit rate mode : Constant
    Bit rate : 384 kb/s
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Frame rate : 31.250 FPS (1536 spf)
    Delay relative to video : -736 ms
    Stream size : 365 MiB (5%)
    Language : English
    Text
    Format : DVB Subtitle
    Codec ID : 6
    Delay relative to video : 1 s 304 ms
    Language : English
    Thanks for any help.
    Jan 2007
    convert using how evver you what
    but you need to edit the commercials first using either a lossless format
    or
    an editing tool with smart rendering, where only the frames affected by the cuts are recoded, the rest are copied
    its going to be a manual operation no matter which way you choose
    i use VideoRedo, for editing my recorded TV broadcasts
    there are other editors with the same abilities, some might be even more advanced
  3. Member netmask56's Avatar
    Sep 2005
    Sydney, Australia
    Maybe TSDoctor or VideoRedo ? Is it from a Panasonic TV? Could be encrypted..
    Jun 2012
    New Zealand
    Thanks for the replies, will have a go with Videoredo (and thanks for suggestion to edit first).
    Yes, it's from a Panasonic (DVD-Recorder) and not encrypted (I can see it in VLC).
    Jun 2012
    New Zealand
    Is there a get started guide VideoRedo for editing? I tried a few things but got nowhere. There's a picture and some thumbnails..but I can't select a piece to cut out. There's a pop up that says mark the beginning/end of a selection but it doesn't seem to do anything. Nor can I move the thumbnails along.... I can get the main picture starting and stopping by clicking on it - but that's about it!
  6. VideoRedo:
    1. Mark in point (there is an icon and also a keyboard shortcut).
    2. Mark out point (ditto)
    3. Cut (your cut will appear in cut list in upper right corner)
    4. Repeat 1,2,3 as needed.
    5. Save AVI
    May 2004
    New Zealand
    Greetings to a fellow kiwi.
    Just out of interest, how are you getting the recordings off the Panasonic recorder?
    I have one as well, which s networked. But the only way I have been able to get material off it is by burning and ripping discs.
    Jan 2007
    open DVD title
    quick fix save stream, as a TS file. PS file, or MPEG file
    then open the saved file for editing
    that is fairly simple, even if it involves more steps
    you can't actually save back to disc or directly edit the disc
    although you should be able to create edit markers and save as a project file to be exceuted
    doing the quick fix stream fix save, removes glitches and timing errors in the recording and gives you a file on the PC to work with
    Jun 2012
    New Zealand
    Thanks for the tip with the video editor, I've had a few OS problems and haven't been able to get back to it yet.
    Chopmeister, this may help - I had the same problem for ages, then discovered if I turned OFF DLNA Conversion in Network settings (on the Panasonic)
    then the Windows 10 folder (mine is \DMR-XW440\HDD\) permits copying just like any other folder. I couldn't copy TO the Panasonic though !
    Jun 2012
    New Zealand
    johnmeyer and thewizard, thanks for the tips. I didn't realise the 'cut' didn't happen immediately, I see now you'd do then all first,then save.
    I'm just doing my first test. Have also found the Help/getting started files etc.
    Do you know how long the trial lasts for? I am tempted to buy it but it's pretty expensive with our exchange rate (as chopmeister will know!)
