@vhelp
My device is not the usb hdmi dongle it's the hdmi pro that is a pcie card with an hdmi port and a separate port for a breakout cable this one supporting composite, svideo, component and analog audio
@Revan654
The codecs I indicated were for masters or intermediate processing as they are lossless they were not intended as a final format
Results 31 to 34 of 34
No need to capture uncompressed with virtualdub you can capture compressed lossless that are much smaller and retain all the original quality.
Depending if you have significative post processing after capture and need to use virtualdub and avisynth.
An easier solution could be using handbrake to transcode the compressed lossless file from virtualdub to x265. Another one will be using mainconcept total code studio which can be frameserved from virtualdub.This last one will be the better as you can capture to compressed lossless with virtualdub do all cut and filtering within virtualdub and avisynth and frame serve after to mainconcept total code studio ( previous mainconcept reference) for a final HEVC format, however this last one is a paid solution.Last edited by FLP437; 3rd Nov 2016 at 12:17.
Download from
https://www.videohelp.com/software/Ut-Video-Codec-Suite
Install and it should be available to virtualdub.
After in virtualdub select from the several codecs included in the utvideo suit the most suitable codec for your particular project related with input/output and namely colorspace , Chroma sub sampling ,bit depth and color matrix / resolution.Last edited by FLP437; 6th Nov 2016 at 16:25.
List of 4k60 video capture cards with onboard hevc compression
By ezcapper in forum Capturing and VCRReplies: 1Last Post: 6th Oct 2016, 21:56 -
High Quality (4K60) RAW DirectShow Capture
By kenaddison in forum Capturing and VCRReplies: 11Last Post: 13th May 2015, 04:07 -
Portable Capture Devices Question
By Revan654 in forum Capturing and VCRReplies: 45Last Post: 17th Sep 2014, 12:49 -
Video Capture Devices, Looking for one
By therock003 in forum Capturing and VCRReplies: 3Last Post: 14th May 2012, 19:46 -
Reliable USB capture devices?
By slats7 in forum Capturing and VCRReplies: 21Last Post: 11th Mar 2012, 20:32
