  1. I recently installed Potplayer v1.6.62949 and noticed that some files have their audio absent. I cycled through the audio codecs installed in Potplayer: Built-in FFmpeg, System MFT, OpenCodecUnity64(libFAAD2), OpenCodecUnity64(FDK), FFmpeg64.dll, but none of them fixed the audio. The audio works fine in VLC player and Media Player Classic so there doesn't seem to be a problem with the files. Here is the file and playback information for two files that have no audio:
    File 1
    General
    Complete name : C:\Users\Int\Desktop\File A022.mp4
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom (isom/iso2/avc1/mp41)
    File size : 433 MiB
    Duration : 23 min
    Overall bit rate : 2 534 kb/s
    Video
    Format : AVC
    Format profile : Baseline@L3.1
    Format settings, CABAC : No
    Format settings, ReFrames : 3 frames
    Format settings, GOP : M=1, N=89
    Codec ID : avc1
    Duration : 23 min
    Duration_FirstFrame : 33 ms
    Bit rate : 2 400 kb/s
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 29.970 (30000/1001) FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.087
    Stream size : 410 MiB (95%)
    Writing library : x264 core 148
    Encoding settings : cabac=0 / ref=3 / deblock=1:0:0 / analyse=0x1:0x111 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=22 / lookahead_threads=3 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=0 / keyint=89 / keyint_min=8 / scenecut=0 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=2400 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Color range : Limited
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    mdhd_Duration : 1433732
    Audio
    Format : AAC
    Codec ID : 40
    Duration : 23 min
    Bit rate mode : Variable
    Bit rate : 128 kb/s
    Channel(s) : 2 channels
    Sampling rate : 44.1 kHz
    Frame rate : 43.066 FPS (1024 spf)
    Compression mode : Lossy
    Stream size : 21.9 MiB (5%)
Name:	File 1 info.png
    File 2
    General
    Complete name : C:\Users\Int\Desktop\File B845.mp4
    Format : MPEG-4
    File size : 530 MiB
    Duration : 29 min
    Overall bit rate : 2 536 kb/s
    Video
    Format : AVC
    Codec ID : avc1
    Duration : 29 min
    Height : 720 pixels
    Color space : YUV
    Bit depth : 8 bits
    Stream size : 502 MiB (95%)
    mdhd_Duration : 1754152
    Audio
    Format : AAC
    Codec ID : 40
    Duration : 29 min
    Bit rate : 128 kb/s
    Stream size : 26.8 MiB (5%)
    mdhd_Duration : 1754221
Name:	File 2 info.png
    Any suggestions would be greatly appreciated.
    Jun 2012
    Gurupi
    Tried to change the splitter for mp4?
  3. Originally Posted by Havokdan View Post
    Just did and now the audio works fine. Thanks!
