Hello,
I have created mpp file in MS project 2010 and after several edits and saving, i tried to open the file and got an error "Project cannot open the file". I have tried reinstall Project...the same result
So my question is how to view damaged mpp file of microsoft project?
Any help will be appriciated.
Does Microsoft Project create backup files? If not, then in the future when editing a project file try to save it under a different name each time you edit. That way you may have a good project file to use if one gets corrupted.
There are some recovery hints doing a Google search on that file type. You could try that if no one here knows how to recover a corrupted mpp file.Extraordinary claims require extraordinary evidence -Carl Sagan -
The best option for you is to recover it from backup if you have one, even if this means losing some edit.Other than that, you could try opening it on another PC (works sometimes) or you could try creating a new project and inserting the corrupt one into it. There's also a tool MPP Viewer Tool which is meant to repair damaged Project files.
Here the link: https://www.viewertool.com/mppviewer.html
Good luck,
Stuart -
The next time you save an important file that you have a lot of time invested in, and you save only ONE copy of that file, and have no backup, rename it as D N D T A.
Do
Not
Do
This
Again.
office 2003 to office 2010, excel files
By vhelp in forum ComputerReplies: 4Last Post: 3rd Jul 2014, 20:50 -
office 2010 skins or themes to look like XP ribbon bar ?
By vhelp in forum ComputerReplies: 1Last Post: 13th Apr 2014, 05:33 -
looking for savy excel users, 2003 and 2010
By vhelp in forum ComputerReplies: 2Last Post: 2nd Jan 2014, 21:02 -
VHS Capture in 2010 tips
By MadMax_911 in forum Capturing and VCRReplies: 26Last Post: 1st Mar 2013, 20:15 -
New.. Microsoft Office 2013 will be tied permanently to one machine.
By ranchhand in forum ComputerReplies: 24Last Post: 20th Feb 2013, 20:37
