Results 1 to 14 of 14
  1. Ok sorry for bothering, but I already asked people who understand about theme, been in IRCs and everything, and got banned from one channel just for asking a simple question, anyway frustrations aside, I have livestreamer installed, and also a dir with mpv+youtube-dl+rtmpdump (and they are installed).
    Anyway, I was trying to make a workaround for a certain stream, I'll give a example link:
    http://www.rtp.pt/play/p2077/john-oliver
    That's the stream for RTP Play a portuguese channel, so what happens is that livestreamer has no support for rtp play, and i've been struggling with youtube-dl+mpv
    Microsoft Windows [Version 10.0.14393]
    (c) 2016 Microsoft Corporation. Todos os direitos reservados.
    C:\WINDOWS\system32>mpv http://www.rtp.pt/play/p2077/john-oliver
    Playing: http://www.rtp.pt/play/p2077/john-oliver
    Failed to open rtmp://rtpvodfs.fplive.net/rtpvod.
    Exiting... (Errors when loading file)
    I tried to read the manual, and searched deep and wide however I do not understand how to workaround streams that ask for rtmp.
    Also I tried livestreamer, it has not support for this kind of stream.
    C:\WINDOWS\system32>livestreamer http://www.rtp.pt/play/p2077/john-oliver
    error: No plugin can handle URL: http://www.rtp.pt/play/p2077/john-oliver
    So sorry for the noob question but do I have to config somehow rtmpdump, and if so how do I do it?
    Thanks!
  3. hi
    mpv 'http://cdn-ondemand-rtp.dcp.adaptive.level3.net/nas2.share/h264/512x384/p2077/index.m3u8?tlm=hls&streams=p2077_1_30092016.mp4.m3u8:1024'
    livestreamer "rtmp://rtpvodfs.fplive.net/rtpvod//mp4:/nas2.share/h264/512x384/p2077/p2077_1_30092016" best
  4. @biezom for future reference how do I get the rtmp link (or the other link) from the browser, must I search in html code? I might also look into the streams
    Edit: I use firefox
    @sysanin
    As I see i set up everything, I even add a path for mpv in windows system properties.
  5. Code:
    view-source:http://www.rtp.pt/play/p2077/john-oliver
    <script>
     RTPPLAY.currentHPListProgram = 2077;
    if ($("#player_prog").length > 0) {
        RTPPLAY.player.newPlayer({ "hls_url": "http://cdn-ondemand-rtp.dcp.adaptive.level3.net/nas2.share/h264/512x384/p2077/index.m3u8?tlm=hls&streams=p2077_1_30092016.mp4.m3u8:1024", "oas_site_page":"rtp.pt/play/ondemand/video/p2077/e252604" , "id":"player_prog","file": "/nas2.share/h264/512x384/p2077/p2077_1_30092016.mp4", "vttfile": "", "image": "http://img0.rtp.pt/EPG/imgth/phpThumb.php?src=/multimedia/screenshots/p2077/p2077_1_30092016.jpg&amp;q=30&amp;v=3&amp;w=350","application": "rtpvod","streamer": "rtpvodfs.fplive.net","width": 620,"height": 350,"autostart": true,"type":"video","mp4":1,"vod":true});
    RTPPLAY.startPage.programPage();
    </script>
  6. @biezom still both don't work,
    C:\Users\Carlos>mpv http://cdn-ondemand-rtp.dcp.adaptive.level3.net/nas2.share/h264/512x384/p2077/index.m3u8?tlm=hls&streams=p2077_1_30092016.mp4.m3u8:1024
    Playing: http://cdn-ondemand-rtp.dcp.adaptive.level3.net/nas2.share/h264/512x384/p2077/index.m3u8?tlm=hls
    Empty playlist!
    Exiting... (End of file)
    'streams' is not recognized as an internal or external command,
    operable program or batch file.
    C:\Users\Carlos>mpv 'http://cdn-ondemand-rtp.dcp.adaptive.level3.net/nas2.share/h264/512x384/p2077/index.m3u8?tlm=hls&streams=p2077_1_30092016.mp4.m3u8:1024'
    Playing: 'http://cdn-ondemand-rtp.dcp.adaptive.level3.net/nas2.share/h264/512x384/p2077/index.m3u8?tlm=hls
    [file] Cannot open file ''http://cdn-ondemand-rtp.dcp.adaptive.level3.net/nas2.share/h264/512x384/p2077/index.m3u8?tlm=hls': Invalid argument
    Failed to open 'http://cdn-ondemand-rtp.dcp.adaptive.level3.net/nas2.share/h264/512x384/p2077/index.m3u8?tlm=hls.
    C:\Users\Carlos>livestreamer "rtmp://rtpvodfs.fplive.net/rtpvod//mp4:/nas2.share/h264/512x384/p2077/p2077_1_30092016" best
    [cli][info] Found matching plugin stream for URL rtmp://rtpvodfs.fplive.net/rtpvod//mp4:/nas2.share/h264/512x384/p2077/p2077_1_30092016
    [cli][info] Available streams: live (worst, best)
    [cli][info] Opening stream: live (rtmp)
    [cli][error] No data returned from stream
    C:\Users\Carlos>
  7. ok
    try mpv "URl_LINK" instead of mpv 'URl_LINK' because i think it's a problem with the ' ' in command prompt on windows so prefer " "
    mpv "http://cdn-ondemand-rtp.dcp.adaptive.level3.net/nas2.share/h264/512x384/p2077/index.m3u8?tlm=hls&streams=p2077_1_30092016.mp4.m3u8:1024"
    and for livestreamer
    try
    livestreamer "rtmp://rtpvodfs.fplive.net/rtpvod playpath=mp4:/nas2.share/h264/512x384/p2077/p2077_1_30092016" best
  8. @biezom thank you so much, it was the syntax, I think I will even build a guide to my own guide in my site for record! Thank you so much!
    Edit: Just to clear things out, the mpv trick worked, but not the livestreamer one, but I don't care I only need one to work
    Last edited by silveringking; 3rd Oct 2016 at 14:12. Reason: Forget to say something
  9. Hi I'm having yet another problem with a stream, this time: http://sic.sapo.pt/direto , it says it fails to download the m3u8:
    C:\Users\Carlos>mpv http://sic.sapo.pt/direto
    Playing: http://sic.sapo.pt/direto
    [ytdl_hook] ERROR: Failed to download m3u8 information: HTTP Error 403: Forbidden (caused by HTTPError()); please report this issue on https://yt-dl.org/bug . Make sure you are using the latest version; type  youtube-dl -U  to update. Be sure to call youtube-dl with the --verbose flag and include its complete output.
    [ytdl_hook] youtube-dl failed, trying to play URL directly ...
    [ffmpeg] http: HTTP error 416 Requested Range Not Satisfiable
    [ffmpeg] Seek failed
    [ffmpeg] Connection lost! Attempting to reconnect (1)...
    [ffmpeg] Connection lost! Attempting to reconnect (2)...
    [ffmpeg] Connection lost! Attempting to reconnect (3)...
    [ffmpeg] Connection lost! Attempting to reconnect (4)...
    [ffmpeg] Connection lost! Attempting to reconnect (5)...
    [ffmpeg] Connection lost! Attempting to reconnect (6)...
    Failed to recognize file format.
    C:\Users\Carlos>
    However I found it in the source and it gave me and error anyway:
    C:\Users\Carlos>mpv "http://live.impresa.pt/live/sic/sic.m3u8"
    Playing: http://live.impresa.pt/live/sic/sic.m3u8
    [ytdl_hook] ERROR: Unable to download webpage: HTTP Error 403: Forbidden (caused by HTTPError()); please report this issue on https://yt-dl.org/bug . Make sure you are using the latest version; type  youtube-dl -U  to update. Be sure to call youtube-dl with the --verbose flag and include its complete output.
    [ffmpeg] http: HTTP error 403 Forbidden
    Failed to open http://live.impresa.pt/live/sic/sic.m3u8.
    C:\Users\Carlos>
    Thanks!
  10. hi
    it's geo-restricted, probably you used a proxy through your web browser but this proxy works just through your web browser and not for all traffic so
  11. example with free proxy (free so not really efficient some lag)
    youtube-dl --proxy "http://94.46.163.111:8080" "http://live.impresa.pt/live/sic/sic.m3u8" -o- |"C:\Users\Carlos\mpv" -
    need ffmpeg in youtube-dl folder
  12. Originally Posted by biezom View Post
    hi
    Yes, I know now, I understand, I know what happened, I'm in Germany and that is a Portuguese website, just one question, does the proxy needs to be Portuguese, how can I figure out the countries allowed?
    Thanks!
