Hi all, I hope you can help me answer a presumably basic question that I've been unable to find an answer for when searching.
I have started doing screen captures for various demonstration purposes. I would like to enhance them with annotations (notes, arrows, boxes, scribbles, doodles, etc.) to highlight particular points (or correct minor mistakes) and I would like to do so after having completed the recording. I would also like to keep these notes separate from the original video stream, i.e. I don't want to merge the overlay permanently onto the video stream. Ideally, I would include multiple overlays in various languages and the viewer could choose which overlay to view - or none at all (similar to how subtitles work).
Is the above possible? And if so, what tools and formats support it?
Thanks in advance!![]()
Whenever I've seen this done, it was permanent, not user selectable.
Google is your Friend -
Actually you have replied your one question without knowing it, and the solution is subtitles, in concrete ass subtitles. The best tool to do it is aegisub/assdraw, it can be a litle complicated for a new user and for some things can be needed a suport tool. After the subtitle is created you only ned to create a mkv with the files.
video overlay
By chamel in forum EditingReplies: 2Last Post: 20th Sep 2013, 10:59 -
Capture two video streams at once (overlay?)
By exon in forum Capturing and VCRReplies: 1Last Post: 27th Nov 2012, 16:30 -
Ripping to mp4 with multiple audio tracks and optional subtitles
By Super Chris in forum Blu-ray RippingReplies: 2Last Post: 4th Aug 2012, 03:10 -
question about overlay
By unclescoob in forum RestorationReplies: 13Last Post: 15th Jul 2012, 14:07 -
Why Am I Getting This Overlay In DVDFab?
By crevice9 in forum Video ConversionReplies: 16Last Post: 10th Feb 2012, 00:02
