Can someone please help me why I get jittery video when tripod panning at 30 frames per second? I am not panning fast but take my time and pan slowly but still wind up with jittery video. I even send it through my editing software and the final result is still jittery. The reason I asked this question is because I see tons of videos on line where people are panning @30fps and not getting the jittery video.
I've tried various shutter speeds and also shot in full auto and still get jittery fact.
Is there a way I can set my camera up so that I can pan at 30fps and get smooth video results?
Thank you!
				Results 1 to 14 of 14
	Make sure any image stabilisation is turned of. Depending on the model of your camera, this might be either OIS (optical image stabilisation) or EIS (electronic image stabilisation)
 Image stabilisation and panning work against each other - and can result in jittery video pans...
	To reduce flicker at 30p use slow shutter speeds (motion blur), narrow depth of field (background blurred), low contrast.
	Please explain how you understand "jitter" - perhaps it is something else than jitter - perhaps it is stutter...
	I think the best way to explain jittery would be to use the word flicker as jagabo, described. I just viewed the video and I did see some problems due to the wrong shutter speed I had set. I will adjust to shutter speed to a much lower setting and see what I come up with.
 Now with all that said I still see flickering as I pan back and forth shooting at 30fps. When I shoot at 60p fps I never see any flickering only when I shoot at 30 or 24.
	As i understand term "flicker" - this word cover things visible as fast luminance change (for example someone place between two video frames a black one) https://en.wikipedia.org/wiki/Flicker_%28screen%29
 "jitter" from my perspective may cover small, fast motion changes (randomly usually) in one, two or more directions
 "stutter" is usually another time domain distortion where video doesn't have smooth motion but overall motion is keep'd (such as panning with some frames duplicated i.e. repeated twice) - usually stutter is regular, i think irregular version of stutter can use word "jerky" to describe visible time domain distortions.
 If 60fps is not a problem you can try to use 60fps and later decimate video by removing unwanted video frames (or you can convert video with using motion compensation techniques).
 Side to this perhaps your acquisition device may introduce this behaviour - you may check manufacturer site for some firmware upgrade.
	Pandy, I don't have a problem uploading a small clip and matter-of-fact I done so and send it to YouTube but decided not to post it. As you know YouTube compresses and when I uploaded it and viewed it on YouTube it was even more choppy, jittery them what I produced. It would've made a very unrealistic example of what I'm trying to portray.
 Yesterday I did a 30p test at 30 shutter and it came out very well. Now it had motion blur but I know that is to be expected at 24 or 30 frames. I'm well familiar with motion blur. One other person within this thread mentioned use a lower shutter. I was using 50, 60 and above before and never thought to go as low as 30. Much to my surprise 30 shutter speed at 30 frames for my camera seems to be fine.
 Thank you!
	Still it can be nice to attach few samples - adding motion blur will improve perceived motions smoothness (fluidity) at a cost of perceived sharpness - this is compromise due low temporal resolution with 24/30fps. Longer exposition is workaround for this... but this is always workaround - real future is for high framerates.
 60 fps and way more (above 300 - 600) this is where all pleasure (smooth/fluid and sharp) starts.
  How to convert 15hour ( 30fps ) long video to timelapse video ( 15mins )?By rplusj1 in forum EditingReplies: 9Last Post: 10th Oct 2015, 19:46
  video tripodBy kj1983 in forum Newbie / General discussionsReplies: 21Last Post: 29th May 2015, 00:29
  Looking to protect my video camera on the tripodBy csmith3pmg in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 28th Mar 2015, 11:06
  streaming video jittery laptop gets hotBy Naytch in forum ComputerReplies: 4Last Post: 4th Apr 2014, 09:53
  Sony Vegas HD Platinum 11 - Jittery PanningBy BrettOnTheNet in forum EditingReplies: 8Last Post: 1st Sep 2013, 00:40
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
