Is there any tool or script that periodically logs the disk space you have left? I tried FolderSizes but it asks me to schedule an exact, specific time which is useless when my computer is shut down. I need it done once a day, no matter what time it is. Also, the software is not free.
will add the text "N Dir(s) N bytes free" for the specified drive to the specified text file. You could run this command once a day from the Task Scheduler with "Run task as soon as possible after a scheduled start is missed" checked.Code:
dir c: | find "free" >> c:\freelog.txt
What is the desired goal? ie: do you actually need a record/log for some reason, or do you simply want to see how much space is used/available?
Google is your Friend -
Sorry, didn't check his status.
It's all good then, never mind.Google is your Friend
Hauppauge PVR 2 1512 bitrate vs. DVD disk space
By gliebisch in forum Capturing and VCRReplies: 4Last Post: 23rd Mar 2015, 09:28 -
how much Hard Disk space needed?
By zoranb in forum Capturing and VCRReplies: 27Last Post: 5th Mar 2014, 01:57 -
Save space in Local Disk (C:)
By DennisChiam in forum Video ConversionReplies: 3Last Post: 10th Mar 2013, 22:28 -
Win 7 x64 Pro misreported disk space
By magillagorilla in forum ComputerReplies: 1Last Post: 14th Apr 2012, 21:58 -
Question about how ImgBurn reckons disk space
By Seeker47 in forum Authoring (DVD)Replies: 3Last Post: 10th Feb 2012, 16:38
