Hello
Sorry if my English is not good, I am going to try to explain it as best as possible.
I have a problem with a .ts file, when I convert to a dvd I get audio delay.
Here is the info for the original .ts file.
General
Complete name : D:\Documents and Settings\My documents\Lietuvos galiūnų čempionato kvalifikacija. Trakai.ts
Format : MPEG-TS
File size : 900MB
Duration : 1h 0min.
Overall bit rate : 2 084Kbps
Video
Menu ID : 1 (0x1)
Format : AVC
Format profile : Main@L3.0
Format settings, CABAC : Si
Format settings, ReFrames : 4marcos
Codec ID : 27
Duration : 1h 0min.
Width : 704pixeles
Height : 576pixeles
Display aspect ratio : 16:9
Frame rate : 25,000fps
Standard : PAL
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8bits
Scan type : MBAFF
Audio
Menu ID : 1 (0x1)
Format : AAC
Format version : Version 4
Format profile : LC
Muxing mode : ADTS
Codec ID : 15
Duration : 1h 0min.
Bit rate mode : Variable
Channel(s) : 2canales
Sampling rate : 48,0KHz
Delay relative to video : -217ms
Menú
Menu ID : 1 (0x1)
Duration : 1h 0min.
List : 256 (0x100) (AVC) / 257 (0x101) (AAC)
Service name : Service01
Service provider : FFmpeg
Service type : digital television
I followed this steps: https://forum.videohelp.com/threads/329652-AVStoDVD-audio-out-of-sync-from-TS-source?p=...=1#post2041822
but if I run the file thru TsRemux I get a new file (821mb), but without audio.
If I skip this first step and do this:
1. Open AVStoDVD.
2. Go to 'Preferences'/'Audio' and toggle off 'Keep AC3/DTS/MP2 DVD Compliant Audio'. Press OK.
3. Add the new ts file to AVStoDVD.
4. Go to 'Edit Title'/'AviSynth', toggle off 'Auto AviSynth Script'
5. Click on 'Delay Audio' and enter "-217" (without quot marks, of course). Press OK
The audio delay still continues...
Please help
Results 1 to 1 of 1
AVStoDVD-audio delay,please help
By JurassicPark in forum Video ConversionReplies: 4Last Post: 14th Dec 2015, 02:52 -
AVStoDVD audio problems
By contraplex in forum Authoring (DVD)Replies: 1Last Post: 30th May 2014, 02:14 -
Menu with Audio in AVStoDVD?
By gastrof in forum Newbie / General discussionsReplies: 7Last Post: 20th Sep 2013, 23:38 -
By jovopros in forum Authoring (DVD)Replies: 5Last Post: 7th May 2013, 01:55 -
Audio out of sync with avstodvd
By p1r473 in forum Newbie / General discussionsReplies: 11Last Post: 27th Jan 2013, 09:38
