For some time, I have been recording off PBS broadcast TV using mythtv. I use Avidemux to cut off the beginning and end of the video (commercials for other shows) so all that's left is the show I want to keep. I've been using default settings for everything. The video and Audio output both set to 'Copy' so it only takes about 20 seconds or so to create the new file in mkv Muxer output format.
The original file is 704x480 and the output file is 704x480. The problem is when I play the output file using VLC or KODI the aspect ratio is messed up. I checked the setting on VLC it says it's using the Default Aspect Ratio. When I change it to 16:9 then it looks more like the original file.
So somewhere the default aspect ratio is being set different than the actual file height/width. Any idea where the setting is in Avidemux so it stops changing it?
thanks
Everend
problem with avidemux change aspect ratio
By jalea148 in forum Video ConversionReplies: 2Last Post: 18th Oct 2015, 16:50 -
Aspect ratio of 1.375? Can Avidemux solve that?
By MovingParts in forum Newbie / General discussionsReplies: 14Last Post: 23rd Sep 2015, 14:40 -
Movie editing/messing with aspect ratio
By frodawgg in forum EditingReplies: 9Last Post: 3rd Dec 2013, 09:18 -
Avidemux aspect ratio question [from newbie to Avidemux]
By ANOther1676 in forum EditingReplies: 1Last Post: 20th Jan 2012, 21:07 -
avidemux - x264/mkv with chapters? + aspect ratio question.
By simon_h in forum DVD RippingReplies: 2Last Post: 22nd Nov 2011, 15:13
