    Sep 2016
    I've been trying to figure out how to do this effect for a while now. I want to know how this guy does it since it is a perfect example of what I want to do.
    https://www.youtube.com/watch?v=AwnQnU2c3DY&index=61&list=LLz-U1FX5WdTlIm4ogY5rh5g
    He does the effect at 0:44 -0:46
    For some reason when I speed up the clip it would never come out as smooth as that so what is he doing to do that??? I would really appreciate it
  2. Bring the footage into your NLE and examine it. His speed up lasts about 10 frames. He's starting with perfectly smooth footage, and he's not doing any blending or interpolating.
  3. You already asked this question and it's already been answered.
    https://forum.videohelp.com/threads/380482-Can-someone-explain-to-me-how-to-do-this-effect?p=2459774
    If you're not getting the results you want you should indicate exactly what you did and provide before and after sample clips.
