i have captured a film as quicktime and when convert to dvd as dvd video - it jitters on the dvd in a way that it does not on the orig mov file
the program i used to burn the dvd video on dvd is called burn (it asked me to convert to mpg2 first though)
had same experience with tmpgenc mastering
as far as i can see it's a standard quicktime 25 fpp file
i am using a mac os x
any thoughts would be appreciated
Results 1 to 12 of 12
I don't know what you mean by "jittery". Upload a short sample of your VOB or MPG file that shows the problem.
It may be incorrect field order however it is very difficult to help without sample of your source.
i have uploaded bothe a sample of the orig qt file and the convrted mpg2 file
Your original mov file contains interlaced frames (originally 16.67 fps with 3:3 hard pulldown to 25 fps, bottom field first) but it is encoded progressive. Since the video wasn't flagged interlaced your editor/encoder treated it as progressive and encoded as MPEG 2 with the same properties. That may cause the fields to be played back in the wrong temporal order -- back and forth motions on some fields. What you want to do is convince your editor that the source is interlaced, bff, and encode with that setting. The low underlying 16.67 fps will still leave the video jerky.
Colorful shots will still have a problem because the original encoding of the interlaced frames as progressive will have blended the colors of the two fields together. But that will be less noticeable than the out of order field playback.Last edited by jagabo; 26th Sep 2016 at 18:32.
It may be interlace (ion interlace) improperly called jitter... not sure if jagabo share my point but i would go for full video processing with motion interpolation...
First I would look into why interlaced frames were encoded progressive. That causes the colors of the two fields to be blended together. When there are large movements of colored objects you will see problems like the image in this post:
https://forum.videohelp.com/threads/380603-How-to-fix-this-frame
You want interlaced video to be encoded interlaced to prevent this.
Since this was originally (8mm?) film the projector was set to 16.67 fps and each film frame was captured as 3 fields. Even when handled correctly, the results will be jerky and flickery. You can use motion interpolation methods to smooth out the motion but that doesn't work well with all video. It works well for panning shots (50 fps sample attached, deshaken and motion interpolated) but can deliver gross artifacts with complex motions. -
hi
that's great and ta
just so you know - i did it and it worked a treat - the jitter almost completely disappeared!!!!
ta all
is there free sw that does the motion interpolation ? -
At least few, lastly ffmpeg received such functionality, side to this there is SVP project and you use Avisynth with or SVP or MVTools.
http://forum.doom9.org/showthread.php?t=164554
have you ever had an image like this one
By sivadsivad in forum Newbie / General discussionsReplies: 1Last Post: 26th Aug 2015, 18:44 -
Can you help me with this image ?
By posserina in forum Newbie / General discussionsReplies: 6Last Post: 1st Mar 2014, 15:31 -
Is onboard tuner image different than cable image of the same channel?
By brassplyer in forum DVB / IPTVReplies: 9Last Post: 13th Jun 2013, 12:27 -
Can we re-image an image?
By aruwin in forum ComputerReplies: 1Last Post: 26th Nov 2012, 13:02 -
Windows7 image backup - restoring the image question
By ranchhand in forum ComputerReplies: 18Last Post: 15th Apr 2012, 07:13
