Hi, people! I used to have a Canon elura 60 NTSC with the classic remove the cassette error, I am planning on buying a used camera to transfer all my old DV tapes to my computer, my question is... If I use the firewire connection as it is a digital signal, will a lose quality if I use a different Video Camera from the one that I had to play the tapes? Any Brand you would like to recommend. thanks in advance!!!. Joe.
no. it's digital on the tape. as long as the new cam can play the tape it is exactly the same as what would transfer off the original cam.
Not necessarily. A camera that doesn't track as well will conceal errors in a way that can degrade picture quality. Dave Rice has created software to analyze and display concealed errors in captured DV files.
Thanks aedipuss!!!! I know there are a lot a brands out there but, any you prefer?
JVRaines, thanks for your comment! I will keep that in mind when I buy the camera.
DV avi has error correction built into the stream. errors can't be "concealed", the are either corrected or not. you either get the image as recorded or you get a dropout, there is no in between.
if you used a canon to record with i'd stick with the same brand as the tape transports will be closer to the original.--
Please read the page I linked, written by a professional video archivist:
As the deck reads tape-based data it utilizes parity data to ensure that the tape is being read correctly. Parity data acts as a secondary data source to be referenced if the primary data is damaged or unreadable. If the data is read improperly and cannot be recovered in the very short amount of time that the deck has to read that section, then the deck will note and write into the file the use of concealment and the strategy applied to the dv stream that is output from the deck.
Strategies employed to conceal the missing video data include:
Type “2” or “A”: Replace area with the same corresponding pixels of the previous frame (most common).
Type “4” or “C”: Replace area with the same corresponding pixels of the next frame.
Type “6” or “E”: Unspecified concealment
Type “F”: This typically manifests as groups of grey blocks appearing where the pixels should be.
The letters here represent the hexadecimal value used in the dv stream to categorize error concealment strategies. These values are written into the file and can be parsed out in order to determine exactly where errors are occurring and how they are being handled.
nvenc compatibility
By amrel in forum Video ConversionReplies: 0Last Post: 29th Nov 2015, 10:02 -
Why did Apple drop the mini 3 but keep the mini 2?
By jyeh74 in forum ComputerReplies: 0Last Post: 10th Sep 2015, 12:15 -
Using Sp/LP mini DV in a Sony Mini DV Player
By Gsmurfet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 21st May 2013, 21:38 -
Mkv compatibility
By kyrcy in forum DVD & Blu-ray PlayersReplies: 2Last Post: 29th Jan 2013, 09:33 -
How to Cut & Merge mini 10 part mini series?
By skorpinok in forum EditingReplies: 5Last Post: 8th Oct 2011, 09:41
