Do cuts have to be made on keyframes? I was hoping for a more exact cut and intend to delete the source files once I've extracted the parts I need so want to make sure I do it correctly and don't mess up the resulting files somehow.
Or you could use a "smart" cutter like SolveigMM Video Splitter to only encode around the cuts. -
Thanks for your reply. Yeah I should've mentioned, I was using copy for video and audio as I don't want anything encoding or changing in any way that would decrease quality. Do you know what would happen to the resulting files if cuts were not made on keyframes? I've made a few test cuts and they seem to playback fine.
Afaik
When choosing copy, the cuts WILL be made on the nearest key frames even if that is not where you marked it, so you either get shorter or longer video than you marked
Unless you have really long gops with strange scene changes you are not likely to notice the difference , most of the time
Avidemux video cutting bug
By nanolab in forum EditingReplies: 5Last Post: 30th Jul 2015, 07:25 -
Avidemux cutting problem
By Jason425 in forum EditingReplies: 3Last Post: 18th Jul 2015, 09:07 -
avidemux cannot open mp4 files
By Narayan in forum LinuxReplies: 15Last Post: 28th Jun 2015, 08:47 -
Stitiching 2 mp4 Files using Avidemux
By Bhakti Satalkar in forum Newbie / General discussionsReplies: 1Last Post: 20th Jun 2014, 02:35 -
Cutting AVCHD/m2ts Files with Avidemux
By glenpinn in forum EditingReplies: 26Last Post: 9th Dec 2012, 09:53
