Hi there,
I have a .mp4 file with .srt subtitles. I need to hardcode subtitles into .mp4 output, but the problem is, I also need to change the position of subtitles ONLY in some places. So out of a few hundred lines, 30 need to be repositioned. How can I do it? I know you can convert subs to .ssa and then set the position, but for all the lines and I haven't found any solution to do it only for some lines.
Thank you in advance for any suggestions.
Results 1 to 11 of 11
http://docs.aegisub.org/3.2/Editing_Subtitles/#the-subtitles-edit-box
12. Vertical margin for this line. 0 means use the margin specified in the style. -
Thank you. Do you know what software should I use to hardcode the subtitles and preserve ass formatting? Whatever I use it just exports video without predefined fonts and positioning.
You can mux the subtitles with the video (MKVToolnix) and use HandBrake/Vidcoder.
That is what I do:
1) Open MKVToolnix > Add video and .ass subtitles > Export
2) Open Handbrake > Load video exported from MKVToolnix > Go to Subtitles > Click "Add Track" > Source button appears below and I can choose from "Foreign Audio Scan" and "1 Unknown (SSA)" so I choose the second one > Start Exporting
3) I receive video with very small and unformatted subtitles.
What do I do wrong?
Exactly the same happens in VidCoder. It sees "1 Unknown (SSA)" subtitle path, so I choose it and I receive video with little subs and no positioning.Last edited by bhra0; 28th Sep 2016 at 13:47.
Here are mine subtitles...
As you can see, from 0,0:01:56.30,0:01:59.95 some lines start with changed position.Last edited by bhra0; 28th Sep 2016 at 14:20.
I edited the ass adding
ASS override tags
The formatting works OK.
PS: Note the resolution in the ass is
PlayResX: 768
PlayResY: 576
What's the video resolution? -
@Videobruger thank you very much for your help. I was my fault, because the values I entered were simply to small - for example I didn't notice antything by moving vertical position by "10", it turned out that I need "100" for my movie and now it is visible. Everything works fine, thanks again.
PS. I actually wonder why nobody came up with an app that would allow to hardcode subs like ass or ssa directly, without muxing it first... -
But then you'll need to know AviSynth instead of MKVToolnix.
And then there are those like Xmedia Recode, MediaCoder ... that can hardcode .ass without muxing -
OK, thanks for letting me know, I will be experimenting with it in the future.
Surely I don't want to use anything that demands using scripts!
How can I change the position of only SOME lines in a subtitle file?
By jrodefeld in forum SubtitleReplies: 4Last Post: 22nd Aug 2016, 01:01 -
A software to hardcode subs with font options (changing color)?
By exwoll in forum SubtitleReplies: 11Last Post: 8th Feb 2016, 12:18 -
Trying to demux MKV file and remux as AVI with hardcode subs
By medicated in forum Video ConversionReplies: 24Last Post: 2nd Aug 2013, 20:48 -
Hardcode srt subs into avi file
By LegendX in forum SubtitleReplies: 1Last Post: 9th May 2013, 15:35 -
is there a software allows me to hardcode srt subs and change their size?
By HeartBreak_Kid in forum SubtitleReplies: 17Last Post: 2nd Jul 2012, 03:52
