  1. I would like to know if there is a way to disable the auto rewind feature.
    Thank you.
    Aug 2010
    San Francisco, California
    There is no such user setting. You could cover the end-of-tape sensor, but then you'd need to experiment carefully to see if the deck stops the transport without damage to itself or the tape.
  3. any other way besides that? I feel that is risky...
    this is what I got from the manual:
    Aug 2010
    You could reprogram the microprocessor.
  5. that'll be a little complicated and time consuming.
