Try DVDFab and download streaming video, copy, convert or make Blu-rays,DVDs! Download free trial !
  1. I backed up a ton of DVDs but apparently without the MDS file
    I know it may not be authentic - but is it possible to get MDS file from a friend with the same TV Shows? He has similar ones as me and has MDS for them. Or does this differ per disc pressing etc?
    Or Option B- is it possible to extract the VIDEO_TS folder from the .iso and try that way?
    So confused.
    I loaded the .ISOs (virtual drive) without a MDS in imgburn and hit the media information icon and it shows this:
    So do the .ISO files already have the layer break information built in? Pretty confused
  2. Member DB83's Avatar
    Jul 2007
    AFAIK imgburn does not make use of the MDS file. It will either select an appropriate layer-break or refuse the burn if there is not one.
  3. ^ I don't believe that is accurate. When I load a .iso it always ends up auto-loading a .MDS file to burn to disc.
    Nov 2003
    West Texas
    Try burning one with ImgBurn. If it cannot find the layer break it will tell you about it.
