I have a few jumpy VHS tapes that I need to capture and edit. I used to do this a long time ago and had bought a Canopus ADVC100. It served me well. However, I used to use Final Cut Pro 7 but that's been buggy since I updated to Sierra.
Final Cut Pro 10 keeps breaking the imported video into multiple clips at a timecode break. Premiere CC stops capturing when there's a timecode break. I don't see any settings that can solve my problem. QuickTime Player does the same thing.
So I'm looking for a reliable piece of Mac software that can capture video from firewire and ignore the timecode breaks. (And keep the audio/video sync'ed.)
Any recommendations? Or any help on making Premiere or FCP 10 ignore the breaks? Or fixing FCP7?
In other words...help.
Results 1 to 12 of 12
Handle it in the hardware domain with a frame synchronizer (a.k.a. "TBC"), either standalone or built into a DVD recorder such as the Panasonic DMR-ES10/15. This will send an unbroken stream of analog frames to your DV converter.
I appreciate the response. But I've got 15 video tapes to capture for home use and the frame synchronizers I'm seeing are all over $500. After those 15 VHS tapes are done, I'm tossing my VCR as I'll never need it again.
You should have looked up the brand and model numbers JVRaines mentioned, and not' TBC'. Those expensive ones have the wrong kind of TBC from what you need. On the other hand, here's a DMR-ES10 for a good deal less:
http://www.ebay.com/itm/PANASONIC-DMR-ES10-DVD-VIDEO-RECORDER-EXC-WORKING-DVD-RAM-R-RW...0AAOSwOdpXxi~p
And I agree, it's much better to fix this when capturing rather than beating your head against a wall trying to make your software programs work with broken video streams. -
But it's still another piece of equipment to buy for 15 video tapes.
I need a software solution. -
I just scored one of the aforementioned DVD recorders for under $50 on eBay. Sometimes you can get one cheap if the optical drive has conked out but the electronics are still working.
If the optical drive has conked out, doesn't that defeat the purpose, though?
No, because all you want to do is run the signal through the player. One cable from VCR to DVDR, another cable from DVDR to ADVC100.
Hi
By spyro10 in forum Capturing and VCRReplies: 3Last Post: 4th Sep 2016, 11:44 -
What Hardware/Software Should I Use to Capture/Edit SD Video from VHS VCR?
By audioresearch in forum Capturing and VCRReplies: 10Last Post: 30th May 2016, 23:17 -
Need Help Choosing Capture Card, TBC, and Software/Settings for VHS/8mm VHS
By Duder_Me in forum Newbie / General discussionsReplies: 1Last Post: 25th Apr 2014, 10:47 -
By Duder_Me in forum Capturing and VCRReplies: 2Last Post: 25th Apr 2014, 09:42 -
Can an S-VHS Player and S-Video Output Cable Benefit Standard-VHS Capture?
By Avagadro1 in forum Capturing and VCRReplies: 34Last Post: 5th Dec 2012, 18:31
Since you don't want to spend any money, though, you will have to try to get a Windows app like
