    Sep 2015
    i have a panasonic home theatre system and i have my tv speakers on 0 or mute
    i noticed that sometimes the audio/visual is out of sync when
    i watch tv from roku or my cable box
    is it my home theatre system?
    thanks in advance
  2. Could be input lag caused by the TV processing (audio before picture). Try to find out if your audio receiver has a delay setting to make up for it. HDMI 1.3 added optional auto lip sync but support is a matter of luck.
    Sep 2015
    the audio delay setting is auto
    should i change it?
  4. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    How is everything connected?
    Delay usually occurs when you have a device connected to the TV and then output audio from the TV to the AVR. Which causes the video to be before the audio. No adjustments (that I'm aware can fix this).
    If all devices are connected to the AVR, and then the video is output from the AVR to the TV, there typically isn't any delay. But if there is, the audio is typically before the video and you simply adjust the delay of the audio to get things in sync.
    Google is your Friend
  5. +1 Krispy Kritter
