What is resolution of broadcast TV signal and how it signal is ok on 16:9 & 4:3 TVs which have different resolution?
North American Digital TV (ATSC) is usually broadcasted at either 1920x1080, 1280x720, or 720/704x480. 16:9 content on a 4:3 TV is usually cropped to 4:3 by the TV. 4:3 content on a 16:9 TV would be filled in by black bars on the left and right side.
Flags tell the TV or receiver what shape (4:3 or 16:9) the incoming broadcast is to handle it accordingly. The actual resolution of the broadcast stream is fixed. For standard definition broadcasts it can be up to 720x576i for PAL and 720x480i for NTSC, but it can be lower in the horizontal. The resolution does not change with aspect ratio – that's what the flags are for.
High definition broadcasts are either 720p or 1080i. -
The frame and thus the pixels get stretched to fit the desired aspect ratio, making the pixel-information a bit rectangular/non-square.
(image from my 2006 archive, so ignore the ‘regular’ adjective ...
For legacy (SD) there is no resolution but bandwidth and in case of USA video luminance bandwidth is approx 4.2MHz - for DVD bandwidth is equal (theoretically) to 6.75MHz (digital 720 pixels in line) - legacy resolution in pixels will be somewhere around 448 pixels ((720:4.2)/6.75).
For wide aspect ratio video size is compressed to fit in normal aspect video and TV expand video size back - bandwidth stay same so number of pixels is constant. -
Converting a sample video file of any resolution to 13000x1080 resolution
By user321 in forum Video ConversionReplies: 6Last Post: 6th Jul 2015, 07:21 -
Video Resolution vs. Desktop Resolution question
By slipd in forum Newbie / General discussionsReplies: 7Last Post: 1st Feb 2014, 07:17 -
Stored Resolution VS Display resolution
By pewe in forum Video ConversionReplies: 6Last Post: 28th Jan 2013, 18:55 -
Non-standard resolution MKV to Standard resolution (1920x802 to 1920x1080
By brack in forum Video ConversionReplies: 2Last Post: 30th Jun 2012, 17:33 -
Encode video with different luminance resolution and video resolution
By kylix999 in forum Video ConversionReplies: 14Last Post: 6th Jun 2012, 07:57
