i have a raw file 1280x720 at 50fps, PAL. File is 17gb.
I tried the 50fps with multiavchd but my Sony br player won't read it. I know some brands won't read PAL. Somehow Sony BDP S360 did, just once.
One attempt to convert (smaller file 2.5gb sample) to 60fps by multiavchd with Transcode was successful but I was unable to duplicate this , which was very frustrating. The same disc was unreadable on my LG bluray player.
Any easy way to convert to something readable and author?
*was not sure if this question should be on the Converting forum or here
ok , made some progress
i was trying to be too complex with the "TV System" setting in multiavchd Author tab -- but just keep it to NTSC and change the FPS in Transcode to 60fps and my Sony did play it. No need to change TV System to PAL (even though the file is PAL). You will get an error in the log but this is harmless on a BR player HD (may not be harmless on a DVD player). Multiavchd authors the Menu in NTSC (not sure how to change to PAL if you are in a PAL country), so keep the TV System to NTSC
Still not playing on my LG blu ray player though.
download 1080/50p or 4k/50p from youtube
By darknesslord in forum Video Streaming DownloadingReplies: 7Last Post: 16th Jun 2017, 08:37 -
50i or 50p?
By Mabel in forum Newbie / General discussionsReplies: 23Last Post: 3rd Mar 2016, 03:06 -
50i or 50p
By DuBsTaR in forum Newbie / General discussionsReplies: 8Last Post: 30th Oct 2014, 16:06 -
Canon Vixia HF R400 AVCHD (60P 28Mbps) vs MP4 (35Mbps, 60P)
By AkaRainer in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 28th Dec 2013, 15:18 -
1080/50p mts to 720/50p mp4 or 1080/25p
By glenpinn in forum Video ConversionReplies: 5Last Post: 5th Feb 2013, 08:42
