Hey im dealing with an issue about subs. My pc's version is english and the installation of windows was made in english so nothing is greek and i got problem with greek subtitles because i cant read them. When i open the .srt i get weird characters (ex: άνοιξε το λιμάνι Μαριέλ). I tried to save the subs as utf8 and unicode but nothing worked, i still get those weird symbols. I also downloed notepad++ but it didnt work neither. However, VLC player is able to read them correctly when im playing the movie. But i just want to make them readable in the notepad, so i can view and edit them any time. What can i do for that situation?
				Results 1 to 18 of 18
	I opened it in Notepad++. Used "Encoding -> Convert to UTF8". Saved it.I also downloed notepad++
	Hello.
 Try it now. I do not know if show correctly now.
 Can you see if all the greek letters are correct?
 Thanks.
 Best regards.
 devil (johner)
	@ HOK1N
 In my case, when I opened in Notepad++ it gave me the greek letters direct. Nothing to be done, except to save it as a new file, as txt file type.
 And after that I opened such txt file using Subtitle Edit and save it again into srt format, using UTF8 encoding. Just in case to avoid any mistake.
 what should i do to make them readable every time i open the srt files in notepad?
 Open /saving the text correctly before, using UTF8 encoding, you can open later using Notepad displaying correctly all the greek letters.
 And even other languages letters / alphabets too, like arabic, chinese, hebrew, etc.
 You can open using Word or similar programs too. Maybe they get you the correct character encoding used on the text.
 Thanks.
 Best regards.
 devil (johner)Last edited by devilcoelhodog; 24th Sep 2016 at 06:48.
	@ sneaker
 No. Just don't.
 Why not? Here I can do it like this way too, if I know the correct language the text was encoded / written.
	Well you could. BUT needs to choose "Greek" as encoding when opening it and UTF-8 when saving.You can open using Word
	Using ΅$oft Word for dealing with plain-text is like using a truck for transporting ONE pencil
 That's not the actual problem since Windows 95, minimum.Originally Posted by OP
 The real problem is, Microsoft keeps the codepage hell alive
 As I suspected, the .srt file you uploaded to this thread is not UTF-8.
 Instead of "protecting" Notepad (and MS Paint) with the TrustedInstaller idiocy,
 Micro$oft should make it *save as Unicode* by default.
 Besides making it understand UNIX and MAC line-endings, of course.Last edited by El Heggunte; 24th Sep 2016 at 09:15. Reason: add emphasis
	Guys is there any latest automatically way we can convert any pgs or sup greek subtitle into srt file?
 If there is can anyone please make me a guide or tell me what to do even with subtitle edit 3.5.6 program.
 Thanks.
	I could do it simply downloading the dictionaries with the button
 [Attachment 46566 - Click to enlarge]
 Star OCR->... ->OK-> File->Save as..
 automatically correct it does not .. you have to verify責任者-MDX
  Greek subtitles problemBy MultiNikos in forum SubtitleReplies: 39Last Post: 1st Oct 2017, 02:51
  Greek subtitles are not appearing correctlyBy BlackAdder2TheRescue in forum SubtitleReplies: 8Last Post: 29th Jul 2013, 20:50
  Pgs greek subtitles where?By fits79 in forum Blu-ray RippingReplies: 2Last Post: 26th Jun 2013, 03:05
  greek subtitles do not show at all!!By eleeeni in forum ffmpegX general discussionReplies: 7Last Post: 14th Jan 2013, 10:11
  unreadable greek subtitlesBy ioakim in forum SubtitleReplies: 8Last Post: 12th Mar 2012, 08:45
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
