Hey guys. So I finally decided to forget about capping to mpeg after discovering the eloquence that is AVI_IO. It had a timer record feature and MJpeg made file sizes quite managable. What more could one ask for? Well, higher resolution for one. 320x240 is not too pretty. So i decided to up the ante. I downloaded the btwincap driver which allows for capturing in higher resolutions.
Here's where I ran into problems:
Btwincap basically takes the place of my WinTV drivers. I got an error saying it couldn't be automatically installed, so I had to manually go to my Wintv drivers, and update them by pointing the the location of the .inf. Upon reboot, the WinTV reset utility nags me w/ an error. I close that and open up AVI_IO. I get a picture in preview mode, but no sound!
Yes, folks. I've tried eveything, audio is set to be recorded, my line in isn't muted in my sound controls, nothing. I even get the same lack of sound in Virtual dub. I would hate to wipe the drivers and revert to the limited Wintv drivers. Anyone have any ideas?
Thanks for listening to all this.
Take care.
-CitiZen Quantum
Results 1 to 1 of 1
better unit than my old wintv pvr usb2
By diablo in forum Capturing and VCRReplies: 0Last Post: 9th Sep 2011, 10:52 -
[Sloved] Hauppauge WinTV PVR-150 capturing using off air cable plug
By Wizard23 in forum Capturing and VCRReplies: 4Last Post: 11th Feb 2011, 22:07 -
WinTV-PVR-150 MCE
By prabha in forum Capturing and VCRReplies: 3Last Post: 13th Aug 2008, 11:39 -
Hauppage WinTV, BTWinCap to Vdub, dropping frames
By elvisish in forum Capturing and VCRReplies: 0Last Post: 4th Aug 2008, 12:03 -
What software for capturing Hi-8 with Hauppauge WinTV 250 PVR USB2?
By boscabru in forum Capturing and VCRReplies: 10Last Post: 5th Mar 2008, 03:19
