  1. Hey guys, been using uncropmkv for awhile now, first time with any issues. Recently changed a 1920x800 to 1920xw1080. Video was fine but somehow the audio was delayed. Ive never had this issue before. Anyone else?
  2. Format : Matroska
    Format version : Version 4 / Version 2
    File size : 4.22 GiB
    Duration : 1 h 45 min
    Overall bit rate : 5 722 kb/s
    Writing application : Lavf57.25.100
    Writing library : Lavf57.25.100 / Lavf57.25.100
    Video
    Format : AVC
    Format profile : High@L4
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Codec ID : V_MPEG4/ISO/AVC
    Bit rate : 4 968 kb/s
    Width : 1 920 pixels
    Height : 800 pixels
    Display aspect ratio : 2.40:1
    Frame rate mode : Constant
    Frame rate : 23.976 (24000/1001) FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.135
    Stream size : 3.67 GiB (87%)
    Writing library : x264 core 146 r2538 121396c
    Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x133 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00
    Default : Yes
    Forced : No
    DURATION : 01:45:39.166000000
    Audio
    Format : AC-3
    Format/Info : Audio Coding 3
    Format settings, Endianness : Big
    Codec ID : A_AC3
    Bit rate mode : Constant
    Bit rate : 640 kb/s
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Side: L R, LFE
    Sampling rate : 48.0 kHz
    Frame rate : 31.250 FPS (1536 spf)
    Compression mode : Lossy
    Stream size : 484 MiB (11%)
    Default : Yes
    Forced : No
    DURATION : 01:45:39.093000000
    Jul 2008
    Old Dominion
    The only time I've experienced A/V synch issues is when something was wrong with the audio. I did notice that your Audio and Video durations are not the same.
  4. Yea I just noticed that as well, but on the original file it plays perfectly fine so I wonder why it affects it after uncropmkv does its thing
  5. Member Ennio's Avatar
    May 2005
    Netherlands
    What you can try is importing the 1920x800 source mkv in mkvtoolnix and remux to new output. Then check if that new output has no a/v sync issues.
    If it's okay, uncrop that new file and see if it comes out okay. Sometimes remuxing with mkvtoolnix fixes certain issues.
  6. interesting, i will give that a go
