    Apr 2006
    I have a lot of mp4 files that I would like to add a second audio track/channel onto them. Can someone help to guide me on how to do this? Thanks so much.
  2. Member Krispy Kritter's Avatar
    Jul 2003
    St Louis, MO USA
    If you can use mkv instead of mp4, you can simply drop the two files into MKVToolNix.
    Google is your Friend
    Apr 2006
    Thanks so much. After researching, I figured it out using ffmpeg:
    ffmpeg -i input.mp4 -i input.mp3 -map 0:v -map 0:a:0 -map 1:a -codec copy output.mp4
  4. Originally Posted by triumph2004 View Post
    Bingo!
