I have recorded two airings of the same show onto my PVR. They are as MTS files which I've separated as MPV and AC3. I'm looking for a program that I can use to cut out the commercials and replace the bad frames from the re-airing without re-encode as unlikely as that seems. Any feedback would be much appreciated.
Smart Cutter is the cheaper option, and VideoReDo is the expensive option, but the VideoReDo trial may be all you need for a one-time project.
mpv playlists
By steve6 in forum Software PlayingReplies: 0Last Post: 19th Jun 2016, 06:45 -
MPV (media player)
By devilcoelhodog in forum Software PlayingReplies: 4Last Post: 3rd Mar 2016, 07:33 -
MPV Difference in Ubuntu and Window
By baoky in forum Video ConversionReplies: 0Last Post: 17th Sep 2014, 16:24 -
How to best convert from MPV to AVI, using MPEG Streamclip or Avidemux ??
By ribbony in forum Video ConversionReplies: 1Last Post: 14th Jul 2012, 03:19 -
Subtitle Edit doesn't play AC3
By allianceserivce in forum SubtitleReplies: 3Last Post: 17th Dec 2011, 11:13
