Hello everyone,
I've recently been struggling with getting a .sup subtitle file synchronize with the video. I tried using SubtitleEdit but it uses OCR to convert images into text all I want to do is just change the timing keeping other settings as it is.
I used SubtitleCreator but it gives the error that the file is not a valid .sub file. DVDSubEdit asks for a .ifo file which I don't have (I extracted these PGS subs from another video file).
Can anyone help me in changing the time of these .sup files?
Well, a way to do it is just let SubtitleEdit OCR the sup into text (don't worry about wrong characters and spelling). Save this srt file and secure it so that you'll always have the proper source timings in case you screw up/get lost in the next step.
Open a copy of it in SubtitleEdit. Import the video you want to sync it with. Try, using only framerateconversion and/or delay settings, to match the subtitle with the video. Write down the right settings.
Then open the source sup into BDSup2Sub and apply your found settings in the conversion window. Then export to new sup file.
Hopes this will work for you.
Cheers -
Or open the .sup again in Subtitle Edit and in the OCR window:Then open the source sup into BDSup2Sub and apply your found settings in the conversion window.
Right click -> Import new time codes (select the edited .srt)
Right click -> Export -> Blu-ray sup -
I never knew this was possible. Thank you videobruger.
Seeing the settings that must be chosen in the SUP export window, isn't there a chance the export progress changes the sup size and horizontal/vertical alignment settings that OP says he wants to keep? I'm thinking of different bottom and center offsets that a sup can have, and also the size that probably will be changed because you have to pick one of the fixed video resolutions? -
Subtitle Edit uses the images "as is". You may change how they are displayed in a player using a different resolution than the original. For a "non-fixed" resolution use the three dots to choose a custom resolution.and also the size that probably will be changed because you have to pick one of the fixed video resolutions?
Convert pac subtitle to something that I can open in Subtitle workshop
By Tiger_1982 in forum SubtitleReplies: 11Last Post: 15th Aug 2015, 21:49 -
Subtitle Help Please
By Next_Apex in forum DVD RippingReplies: 1Last Post: 7th Aug 2012, 12:27 -
convert 1 CD subtitle to 2 CD subtitle
By nirbhayn in forum EditingReplies: 7Last Post: 10th Apr 2012, 04:44 -
Subtitle help with VLC and MPC using DVD and external subtitle
By enigmakid in forum SubtitleReplies: 2Last Post: 2nd Feb 2012, 01:48 -
subtitle MKVCleaver subtitle file type
By falconmick in forum Newbie / General discussionsReplies: 1Last Post: 26th Sep 2011, 03:30
