Hello everyone. I had to make a short/no-budget documentary for class and my problem is the audio of my footages is not leveled. Some of the sounds and dialogues been recorded with the camera, some with a voice recorder and couple of them with a mobile phone. So some of them are loud, some noisy and some in low-volume. What would be the quickest and easiest way to adjust all of them in a same level?
Many thanks in advance.
As you didn't provided sufficient number of details (formats, compression, preferred software environment and most important - your expectations) it is hard to provide simple answer for such question however based on my experience i can recommend ffmpeg with dynaudnorm filter as it will create homogenic (consistent) perceived loudness level in all files and can do such conversion in a highly automatic way (depends on your preferences - drag & drop or whole folder with file extension mask).
Very similar problem to yours: https://forum.videohelp.com/threads/380396-Volume-Level-Equalizing-a-Bunch-of-MP3-files...o-it?p=2459165
And my answer: https://forum.videohelp.com/threads/380396-Volume-Level-Equalizing-a-Bunch-of-MP3-files...=1#post2459233 -
After you match loudness, you will need to perform spectral equalization because your sources are so diverse. Otherwise, they will still sound jarringly different. (Unless that's what you want.)
Thanks a lot pandy and JVRaines. I'll try all of the solutions and come back with the feedbacks.
This process is call "Mixing" and the best way is to do it by hand and ear in your NLE software or dedicated audio editing software.
Adjust volume level (gain) of MP3s WITHOUT loss of quality possible?
By pxstein in forum AudioReplies: 3Last Post: 27th Mar 2016, 00:59 -
got a Videofile with 2 audios....
By VideoNoob123 in forum Newbie / General discussionsReplies: 2Last Post: 18th Oct 2014, 07:37 -
Converting videos and audios has never been so easy.
By Chris K in forum Video ConversionReplies: 10Last Post: 6th Aug 2014, 06:15 -
batch reencoding level 5 to level 4.2 mkv
By d_unbeliever in forum Video ConversionReplies: 6Last Post: 9th Aug 2013, 06:30 -
Can Xvid4PSP 6 automatically adjust volume to a reasonable level?
By Short in forum Video ConversionReplies: 0Last Post: 24th Feb 2013, 02:15
