I'm using Staxrip and am trying to find a good combination of settings for high quality rips.
Before everything gets redirected to the point of x264 vs. h264 or software vs. hardware encodes or which is better. I know the pros and cons of each and for archiving I'd simply use MeGui as I have in the past.
For this purpose, I simply want to rip my most commonly watched TV shows/music videos to store on my NAS for easy access/watching.
To start off with, I have an Intel HD 4600 chip with quick sync.
I was trying LA-ICQ with a quality setting between 20-26, usually depending on the resolution or the amount of action in the video. Recently, I checked some of the 1080p clips with an application called Bitrate Viewer and was surprised to see that at some point the peaks are exceeding 120,000 kbps. I noticed some other issues as well.
Are there any ways that I can still use the ICQ with lookahead and put a limit on the peak values?
Any other suggestions on really good constant quality with lookahead setting while keeping the bitrates reasonable?
I'm really not that familiar with Quick sync. I that some of the same settings use different terms/words for the same thing in x264 and h264 (for instance CQP & crf), that's about it.
Thanx in advance...
Results 1 to 1 of 1
The Complete Guide To Making Blu-Ray Backups (1:1 Backups + BD5 Backups)
By milOtis in forum User guidesReplies: 225Last Post: 21st Jul 2024, 04:35 -
Blu-ray player won't play backups
By Yanta in forum DVD & Blu-ray PlayersReplies: 12Last Post: 13th Jun 2015, 01:18 -
multiAVCHD Blu Ray content on DVD-R problems in Blu Ray player
By erek in forum Authoring (Blu-ray)Replies: 9Last Post: 6th Aug 2013, 22:25 -
Blu-Ray burner wont recognize my Blu-Ray disc, Only DvD dics?
By PurkkaPoika in forum Authoring (Blu-ray)Replies: 5Last Post: 10th Jul 2012, 14:26 -
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 04:15
