Sorry for the vague title.
Basically, I'm wondering about how to "cheat" when rendering 30FPS videos to give them a 60FPS feel to them (not sure if this involves some kind of interpolation filtering, motion blurring, or what).
For example, if you follow this link (apologies for the morbid subject matter), at 15:08 you'll notice that even in a 30FPS video, there is a segment here which very accurately mimics 60FPS footage. This was the only example that I could think of off the top of my head. Worth noting is the video at that point in the link was likely captured from an interlaced source, and that the channel operator probably did it by complete accident.
Only reason this would be useful is if I'm uploading something to a medium that only displays 30FPS video, such as Facebook.
Dark, low contrast, fuzzy video, and motion blur (really multiple exposure) by blending multiple frames. It won't work well with bright, high contrast material and lots of motion.
Since the uploader of the video very likely didn't do any processing to that clip whatsoever, did it likely only come out that way because the source material was 60FPS and the encoder just knew how to properly interpolate the frames?
If you want a 60 fps feel, you must create intermediate frames. This is done either by blending adjacent frames or through motion interpolation.
It was likely rendered that way by the console. One way to simulate something like it is the following in AviSynth:
The output at frame 0 is a blend of frames 0, 1, 2, and 3. The output at frame 1 is a blend of frames 1, 2, 3, 4. Etc.Code:src = WhateverSource() # a 30 fps source last = src v1 = Merge(SelectEven(), SelectOdd()) v1 = Merge(v1.SelectEven(), v1.SelectOdd()) last = src.Trim(1,0) v2 = Merge(SelectEven(), SelectOdd()) v2 = Merge(v2.SelectEven(), v2.SelectOdd()) last = src.Trim(2,0) v3 = Merge(SelectEven(), SelectOdd()) v3 = Merge(v3.SelectEven(), v3.SelectOdd()) last = src.Trim(3,0) v4 = Merge(SelectEven(), SelectOdd()) v4 = Merge(v4.SelectEven(), v4.SelectOdd()) Interleave(v1,v2,v3,v4) AssumeFPS(src.framerate)
Might try the avisynth filter from MSU, works well enough.
http://www.compression.ru/video/frame_rate_conversion/index_en_msu.html
Is it possible to convert a 60fps DTV stream to 30fps for DVD authoring?
By Xoanon in forum Video ConversionReplies: 13Last Post: 9th Nov 2015, 23:24 -
Can't figure out how to convert 60fps to 30fps with vdub/ripbot264
By 0-01 in forum Newbie / General discussionsReplies: 2Last Post: 20th Nov 2013, 08:20 -
Which is better video: 1080i 60i/30fps or 720p 60fps?
By jbitakis in forum Video ConversionReplies: 7Last Post: 9th Dec 2012, 05:59 -
How do I convert 60fps to 30fps to halve file size?
By DigitalOxygen.ca in forum MacReplies: 33Last Post: 11th Jul 2012, 22:27 -
Encoding 30fps from 60fps source, keep maximum smoothness?
By squall0833 in forum Video ConversionReplies: 22Last Post: 13th Apr 2012, 00:57
