Hi there,
I decided to use VirtualDub to compress some of my large video files and the 1st time it worked fine.
I try and do another one, select Video -> Compression, select my codec & press OK, then nothing happens.
I've tried uninstalling & installing VirtualDub & the codec i'm using, i've even updated my driver but to no avail.
If anyone can help me, it would be much appreciated![]()
The first time it worked, I did Video -> Compression -> OK - That worked. Then I went Save As AVI..
I have done that few times when it hasn't to see if I've done anything wrong, have I done some kind of error? -
I think I've just figured out what the problem was Sambat, I was under the impression that the video compresses when I press compression, I checked some video tutorials and just seen that I was wrong.
Thank you for responding anyway mate.
VirtualDub stopped working - can't open any files or compression menu
By Ananymous in forum Newbie / General discussionsReplies: 24Last Post: 7th Aug 2015, 07:39 -
tsmuxer has stopped working
By svsdurant in forum Authoring (Blu-ray)Replies: 2Last Post: 26th Jan 2015, 15:47 -
Honestech video capture device stopped working
By jglefler in forum Capturing and VCRReplies: 13Last Post: 14th Jan 2013, 23:41 -
Compression of a video using ffdshow in virtualdub
By vinz508 in forum Newbie / General discussionsReplies: 29Last Post: 16th May 2012, 08:15 -
Corel Video Studio Pro x4 has stopped working?
By TheKillerQueen in forum Capturing and VCRReplies: 6Last Post: 24th Mar 2012, 13:49
