Hi. With the help of this forum I've become quite good at using avisynth to correct and convert DVDs. The next skill I want to get to grips with is slow motion. This is the script I'm working on:
global MeGUI_darx = 4
global MeGUI_dary = 3
LoadPlugin("E:\MeGUI\tools\avisynth_plugin\NicAudio.dll")
LoadPlugin("E:\MeGUI\tools\dgindex\DGDecode.dll")
a=DGDecode_mpeg2source("E:\testvid.d2v")
b=NicAC3Source("E:\testvid.ac3")
audiodub(a,b)
QTGMC()
trim(57,8180)++trim(8278,14740)++trim(12862,12990) ++trim(12862,12990)++trim(12862,12990)
I only wish the final scene (12862-12990) to be slomo. Audio synch is not an issue, I'll be overdubbing some music later. Can anyone suggest how I can do this? I found this post by jagabo:
https://forum.videohelp.com/threads/335908-How-can-I-get-the-smoothest-slow-motion-out-...=1#post2085931
which suggests that SmoothFPS is what I need but I just couldn't fathom how to incorporate his script into mine.
Supplementary question: the last scene is repeated twice. Can I script it a bit more tidily than simply saying ++trim(12862,12990)++trim(12862,12990)++trim(12862 ,12990)?
My thanks to anyone able to assist.
If you want to use SmoothFPS2() from that post:
Change the "4" in the SmoothFPS2 arguments to set the speed you want. Note that motion interpolation like this doesn't work well with some types of video. Especially cartoons.Code:function SmoothFPS2(clip source, int num, int den) { super = MSuper(source, pel=2, hpad=0, vpad=0, rfilter=4) backward_1 = MAnalyse(super, chroma=false, isb=true, blksize=16, searchparam=3, plevel=0, search=3, badrange=(-24)) forward_1 = MAnalyse(super, chroma=false, isb=false, blksize=16, searchparam=3, plevel=0, search=3, badrange=(-24)) backward_2 = MRecalculate(super, chroma=false, backward_1, blksize=8, searchparam=1, search=3) forward_2 = MRecalculate(super, chroma=false, forward_1, blksize=8, searchparam=1, search=3) backward_3 = MRecalculate(super, chroma=false, backward_2, blksize=4, searchparam=0, search=3) forward_3 = MRecalculate(super, chroma=false, forward_2, blksize=4, searchparam=0, search=3) MBlockFps(source, super, backward_3, forward_3, num, den, mode=0) } global MeGUI_darx = 4 global MeGUI_dary = 3 LoadPlugin("E:\MeGUI\tools\avisynth_plugin\NicAudio.dll") LoadPlugin("E:\MeGUI\tools\dgindex\DGDecode.dll") a=DGDecode_mpeg2source("E:\testvid.d2v") b=NicAC3Source("E:\testvid.ac3") audiodub(a,b) QTGMC() slow = trim(12862,12990).SmoothFPS2((int(framerate*4), 1).AssumeFPS(framerate) # slow to 1/4 speed trim(57,8180)++trim(8278,14740)++trim(12862,12990)++trim(12862,12990)++slow
There are many other variations of this. Interframe() might work a little better. -
Many thanks, jagabo and pippas. I'll look into pippas' suggestion later but, for now, jagabo's script did just fine (despite there being a superfluous '(' in the penultimate line!).
Thanks again folks. -
Ah yes, I lost count. There should only be one open parenthesis after SmoothFPS2, not two.
How to make a slow-motion fragment in VSDC Free Video Editor?
By Katty.Fine in forum EditingReplies: 2Last Post: 10th Jun 2016, 04:14 -
How to do slow motion video?
By digicube in forum RestorationReplies: 18Last Post: 2nd Feb 2016, 16:25 -
Fixing screen shake on part of a video with Avisynth
By VideoFanatic in forum RestorationReplies: 9Last Post: 7th Sep 2013, 13:34 -
Video slow motion
By efiste2 in forum EditingReplies: 6Last Post: 16th Dec 2012, 09:32 -
MP4Cam2AVI converts my video to slow motion
By sozuki in forum Video ConversionReplies: 2Last Post: 5th Jan 2012, 17:31
