x265 has frequent new updates, and staxrip doesn't have that many updates frequently. Currently Staxrip has Multi library x265 (with 8, 10 and 12 bit). From where can I download this new build of latest x265 multi lib versions so I can replace them in Staxrip?
These don't seem to be multi library. Currently the x265 encoder v 1.9 in the Latest Staxrip version 1.3.7.0 is 15mb in size, it is supposedly for 8,10,12 bit encoding.
I checked the latest file in the list x265_2.0+54-e5ca9b210223.GCC610, and it's only a 4mb file. Multi library is at least 15mb file. Please point it out if you know where to look.
That's a 7-Zip archive. There are .EXE and .DLL files inside of it.
For Your Information:
https://en.wikipedia.org/wiki/Archive_file
and
https://en.wikipedia.org/wiki/List_of_archive_formats
Anyway — you'd better check whether StaxRip will support x265 versions 2.xx correctly...
If I am not mistaken, there have been various changes in the command-line syntax.
StaxRip
By stax76 in forum Video ConversionReplies: 719Last Post: 12th Dec 2025, 12:23 -
x265 Encoder Script
By mgt1234 in forum Video Streaming DownloadingReplies: 18Last Post: 1st Jan 2018, 16:54 -
looking for x265 encoder
By jamespoo in forum Video ConversionReplies: 1Last Post: 12th Aug 2016, 05:12 -
Need x265 encoder
By Artas1984 in forum Newbie / General discussionsReplies: 3Last Post: 19th Jan 2016, 11:41 -
[Encoder x265]
By AsadAli in forum Newbie / General discussionsReplies: 1Last Post: 8th May 2015, 16:42
