I'm trying to edit 24bit audio from a DVD. It's typical 48khz - 1536kbps. When I import into Adobe Audition 3 or CC 2015 the left channel is fine but the right channel is just a block of noise.. Does anybody know what is wrong? Advice on how to edit? Thanks..
	I ripped the vobs with DVD Decrypter. Then demuxed the wave with Tsremuxer.. However, I just demuxed a clip directly with decrypter.. It looks like it loads into Adobe fine..
 Thanks but it might be fixed now. If not, I'll be back..
	almost all dvd video is 16 bit 48k 1536kbps. and what pandy is telling you is that you have your facts wrong. 24 bit pcm 48k wav is 2304kbps not 1536kbps. --
	I understand what you're saying.. I was reading mediainfo for the vob file when I posted that.. (specs below)
 Looking at the wave file by itself it does say 2304kbps. Regardless, I'm able to edit in Adobe now..
 Audio #2
 ID : 189 (0xBD)-160 (0xA0)
 Format : PCM
 Format settings, Endianness : Big
 Format settings, Sign : Signed
 Muxing mode : DVD-Video
 Duration : 1h 11mn
 Bit rate mode : Constant
 Bit rate : 1 536 Kbps
 Channel(s) : 2 channels
 Sampling rate : 48.0 KHz
 Bit depth : 24 bits
  Why does Bluray TV series have 16bit and 24bit audio on same disc?By VideoFanatic in forum AudioReplies: 7Last Post: 15th Mar 2016, 14:58
  Decompress flac 5.1 24bit 48 khz to wavBy anana in forum AudioReplies: 2Last Post: 5th Mar 2015, 09:34
  YV12(12bit) vs AVC1(24bit)By FurqanHanif in forum Newbie / General discussionsReplies: 8Last Post: 11th Jan 2015, 10:59
  24bit/96khz DVD-A?By Zeppmeister in forum AudioReplies: 12Last Post: 29th Aug 2014, 13:33
  Going from 24bit 5.1 DTS to 16bit 44.1KHz 2-ch CDBy carlmart in forum AudioReplies: 5Last Post: 3rd Dec 2013, 10:19
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
