Results 1 to 14 of 14
  1. Hi. I've recorded some online videos in Chrome browser using Screencastify extension. I've downloaded the video to my desktop in .webm format as it is the only one Screencastify uses. When I play those videos back, the audio track is there and plays correctly, but after I've converted them to .mp4 using Handbrake or Vidcoder, there is no audio. I've gone through all of the settings and can't seem to find anything that would correct that. What am I missing? Thanks.
    Aug 2013
    Central Germany
    We are missing a detailed report how you set up your converters, if you configured the audio conversion part at all, which format, bitrate, etc.; and if they are able to create a log file about the conversion job, it would be useful too.
    The MP4 container supports only a few selected audio formats, most important AAC and MP3 – but certainly neither Vorbis nor Opus (as probably used in WebM), therefore converting audio would be required. AAC would be optimal, but distributing ffmpeg or derived software including an AAC encoder in binary form is not allowed by their license, therefore you may have to step back to MP3 as audio format (LAME library).
  3. Which license? Zeranoe build can encode to AAC, is it wrong?
  4. DECEASED
    Jun 2009
    Heaven
    Even though MP4Box and Haali Media Splitter have supported Vorbis in MP4 "since ages ago"...
    Aug 2013
    Central Germany
    It may depend on the specific available AAC encoder. Among the mentioned in Trac, FDK-AAC has the best quality, but like the simpler and older FAAC, both have a license not compatible to the GPL, therefore you may not distribute a binary mixed with other GPL compliant projects. You may only build it from sources for your private use.
    The third mentioned library "aac" is not known to me in detail.
    Current Zeranoe builds do not list using any AAC codec. I don't know how old the version is which you refer to, shekh. You will also have to read the generated help pages carefully, not all formats mentioned as "supported" are also included with a matching encoder library, it may be only decoded, or even only recognized.
    _
    Vorbis in MP4? Are you sure? Anyone please show me where MP4 specs allow this kind of audio stream ... if at all, then probably in a "private" substream. Dolby Digital (AC-3) is a very common extension, possibly even mentioned in MP4 specs, but Vorbis would really surprise me.
  6. I just run quick command with current build (20160919)
    "-c:a aac"
    it worked.
    Thanks for explaining about FDK-AAC. I am not as much concerned with best aac quality, assume ffmpeg internal aac encoder is all right.
    Aug 2013
    Central Germany
    OK, a really recent Zeranoe ffmpeg build contains a libav AAC encoder.
    Now to use it in Handbrake or VidCoder as well, someone would need a just as recent build of them.
    Still, we are waiting for 'Cruisecontrol' to report details as verbose as necessary.
  8. Thank you for your replies. I have listed as much info as I am aware of below:
    I am using VidCoder v1.5.34.0(x64)
    Windows 10 Home v10.0.14393 Build 14393
    CPU: AMD A10-7890K Radeon R7
    Settings from Audio tab:
    - Codec: AAC (avcodec)
    - Bitrate: Auto
    - Target stream: All
    - Mixdown: Stereo
    - Gain: 0
    - DRC: 0
    - Sample Rate: Same as source
    - Passthrough if possible (box is checked)
    - + Add audio encoding (nothing listed)
    Here are the log results from my latest attempt just now. Sorry about the smilies - they are supposed to be : D & : s
    ## VidCoder 1.5.34.0 (x64)
    # Starting job 1/1
    # Path: C:\Users\josep\Desktop\Untitled Screencast.webm
    # Title: 1
    # Range: All
    # Worker ready: Service state is Opened on pipe VidCoderWorker.213b08b0-fd41-4a15-91ec-11dc041d02f2
    # Connecting to process 2176 on pipe VidCoderWorker.213b08b0-fd41-4a15-91ec-11dc041d02f2
    [10:24:09] hb_init: starting libhb thread
    [10:24:09] CPU:
    [10:24:09] - logical processor count: 4
    [10:24:09] OpenCL device #1: Advanced Micro Devices, Inc. Spectre
    [10:24:09] - OpenCL version: 2.0 AMD-APP (2117.8)
    [10:24:09] - driver version: 2117.8 (VM)
    [10:24:09] - device type: GPU
    [10:24:09] - supported: YES
    [10:24:09] Intel Quick Sync Video support: no
    [10:24:09] hb_scan: path=C:\Users\josep\Desktop\Untitled Screencast.webm, title_index=1
    libbluray/bdnav/index_parse.c:162: indx_parse(): error opening C:\Users\josep\Desktop\Untitled Screencast.webm/BDMV/index.bdmv
    libbluray/bdnav/index_parse.c:162: indx_parse(): error opening C:\Users\josep\Desktop\Untitled Screencast.webm/BDMV/BACKUP/index.bdmv
    libbluray/bluray.c:2182: nav_get_title_list(C:\Users\josep\Desktop\Untitled Screencast.webm) failed
    [10:24:09] bd: not a bd - trying as a stream/file instead
    libdvdnav: Using dvdnav version 5.0.1
    libdvdread: Encrypted DVD support unavailable.
    libdvdreadVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.IFO failed
    libdvdreadVDOpenFileUDF:UDFFindFile /VIDEO_TS/VIDEO_TS.BUP failed
    libdvdread: Can't open file VIDEO_TS.IFO.
    libdvdnav: vm: failed to read VIDEO_TS.IFO
    [10:24:09] dvd: not a dvd - trying as a stream/file instead
    Input #0, matroska,webm, from 'C:\Users\josep\Desktop\Untitled Screencast.webm':
    Duration: 02:03:21.20, start: 0.000000, bitrate: N/A
    Stream #0.0: Video: vp8, yuv420p, 1920x950, PAR 1:1 DAR 192:95, 1k fps, 1k tbn (default)
    Stream #0.1: Audio: [0][0][0][0] / 0x0000, 8000 Hz, 2 channels (default)
    [10:24:09] dxva2xFindVideoServiceConversion failed
    [10:24:09] scan: decoding previews for title 1
    [10:24:09] scan: 10 previews, 1920x950, 23.976 fps, autocrop = 0/0/0/0, aspect 2.02:1, PAR 1:1
    [10:24:09] libhb: scan thread found 1 valid title(s)
    [10:24:10] 1 job(s) to process
    [10:24:10] starting job
    [10:24:10] sync: expecting 177451 video frames
    [10:24:10] job configuration:
    [10:24:10] * source
    [10:24:10] + C:\Users\josep\Desktop\Untitled Screencast.webm
    [10:24:10] + title 1, chapter(s) 1 to 1
    [10:24:10] + container: matroska,webm
    [10:24:10] * destination
    [10:24:10] + C:\Users\josep\Desktop\Untitled Screencast.mp4
    [10:24:10] + container: MPEG-4 (libavformat)
    [10:24:10] * video track
    [10:24:10] + decoder: vp8
    [10:24:10] + filters
    [10:24:10] + Framerate Shaper (0:27000000:1126125)
    [10:24:10] + frame rate: same as source (around 23.976 fps)
    [10:24:10] + Crop and Scale (1920:950:0:0:0:0)
    [10:24:10] + source: 1920 * 950, crop (0/0/0/0): 1920 * 950, scale: 1920 * 950
    [10:24:10] + loose anamorphic
    [10:24:10] + storage dimensions: 1920 * 950, mod 2
    [10:24:10] + pixel aspect ratio: 1 / 1
    [10:24:10] + display dimensions: 1920 * 950
    [10:24:10] + encoder: H.264 (libx264)
    [10:24:10] + preset: veryfast
    [10:24:10] + profile: main
    [10:24:10] + level: 4.0
    [10:24:10] + quality: 20.00 (RF)
    [10:24:10] reader: first SCR -630 id 0x0 DTS 630
    [10:24:10] encx264: min-keyint: 24, keyint: 240
    [10:24:10] encx264: encoding at constant RF 20.000000
    [10:24:10] encx264: unparsed options: level=4.0:ref=1:8x8dct=0:weightp=1ubme=2:mixed-refs=0:trellis=0:vbv-bufsize=25000:vbv-maxrate=20000:rc-lookahead=10
    x264 [info]: x264 [info]: x264 [info]: [10:55:07] reader: done. 1 scr changes
    [10:55:08] work: average encoding speed for job is 86.813232 fps
    [10:55:08] mux: track 0, 161274 frames, 1985859366 bytes, 2146.52 kbps, fifo 2048
    [10:55:08] sync: got 161274 frames, 177451 expected
    [10:55:08] render: lost time: 0 (0 frames)
    [10:55:08] render: gained time: 0 (0 frames) (0 not accounted for)
    [10:55:08] vp8-decoder done: 161274 frames, 0 decoder errors, 0 drops
    x264 [info]: x264 [info]: x264 [info]: x264 [info]: x264 [info]: x264 [info]: x264 [info]: x264 [info]: x264 [info]: x264 [info]: x264 [info]: x264 [info]: x264 [info]: [10:55:08] libhb: work result = 0
    # Job completed (Elapsed Time: 30m 59s)
    canada
    When you select the video is there any audio displayed?If not then it's an audio type vidcoder doesn't recognize since the audio codecs isn't mentioned in the log.Post a mediainfo of the video,just paste the text in a post.
  10. Originally Posted by johns0 View Post
    Thanks. I'm not sure what you mean by "audio type", but here's the info from MediaInfo:
    General
    Unique ID : 240969497283573712525939048670766797935 (0xB549097C1FD5A451B8F13761F9EF946F)
    Complete name : C:\Users\josep\Desktop\Untitled Screencast.webm
    Format : WebM
    Format version : Version 4 / Version 2
    File size : 4.40 GiB
    Duration : 2 h 3 min
    Overall bit rate : 5 108 kb/s
    Writing application : w69b-mediawriter
    Writing library : w69b-mediawriter
    IsTruncated : Yes
    Video
    Format : VP8
    Codec ID : V_VP8
    Width : 1 920 pixels
    Height : 950 pixels
    Display aspect ratio : 2.021
    Frame rate mode : Variable
    Compression mode : Lossy
    Default : Yes
    Forced : No
    Audio
    Format : Opus
    Codec ID : A_OPUS
    Channel(s) : 2 channels
    Sampling rate : 8 000 Hz
    Bit depth : 16 bits
    Delay relative to video : -7 ms
    Default : Yes
    Forced : No
  11. Originally Posted by johns0 View Post
    Oops. Never mind the part in my previous post where I said I didn't know what you meant by "audio type." My reading comprehension is fading with old age.
  12. Looks like OPUS decoding isn't supported in HandBrake (unless the nightly build has it). Use XmediaRecode instead.
  13. Originally Posted by johns0 View Post
    Success! I looked at the mediainfo audio format and noticed that my .webm file used the Opus codec. Then I took a look at the VidCoder site again and saw that the Beta version now includes Opus. So, 2+2=4 and I downloaded the Beta version of VidCoder and ran my video again, et voila, the audio now works in the .mp4 file. Thanks for your help and for guiding me in the right direction. Thanks also to everyone who replied with their help and suggestions. Much appreciated!
