Is it possible to format a subtitle and add a hyphen to the begining and end of a continuing subtitle line? Like this:
Example sub (.srt):
TO THIS:Code:1 00:00:48,966 --> 00:00:53,720 Today he was so angry and happy at the same time, 2 00:00:53,929 --> 00:00:57,683 he went to the store and bought a couple of books. Then the walked home 3 00:00:57,849 --> 00:01:01,102 with joy and jumped in the pool. 4 00:00:57,849 --> 00:01:01,102 One day he was in a bad mood and he didn't get happier when he read.
Code:1 00:00:48,966 --> 00:00:53,720 Today he was so angry and happy at the same time- 2 00:00:53,929 --> 00:00:57,683 -he went to the store and bought a couple of books. Then the walked home- 3 00:00:57,849 --> 00:01:01,102 -with joy and jumped in the pool. 4 00:00:57,849 --> 00:01:01,102 One day he was in a bad mood and he didn't get happier when he read.
This is the standard for scandinavian subtitles. I'm used to read subtitles in this way.
I can't figure out how to format an existing subtitle to match this "pattern". A little bit of help please. Which program should I use? Subtitle Edit?
Thank you.
In English captioning style, do not use dashes unless a sentence is interrupted for emphasis, or by another sound or speaker. (Hyphens are only for compounds.) Take care not to break phrases across captions. For example, your first three captions should be
Then he walked home with joy
and jumped in the pool.Last edited by JVRaines; 16th Sep 2016 at 20:25.
Maybe show an example in your language with the dash a different colour etc. Is the dash an N dash or an M dash ? Not sure if either of those could cause a problem.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Sorry, I misunderstood about the language. I believe my advice to avoid breaking phrases would apply to any Western language, but of course it's up to your preference.
I would use a regex search-and-replace in a text editor such as Notepad++. Here is the logic you need to implement:
1. Add a dash after any alphabetic character which is followed by two newlines.
2. Add a dash before any lowercase alphabetic character which is preceded by a numeral and a newline. -
That's what I'm searching for. Thanks... I'm not a programmer so this seems very difficult. Could you please be more specific? What sould I replace nothing with? Is it also possible to add the dash to a line with italic tags?
Subtitle edit new line hotkey?
By lllllllllllllllllllllll in forum SubtitleReplies: 2Last Post: 15th Sep 2016, 06:34 -
AviSynth Subtitle Line Break
By smike in forum EditingReplies: 5Last Post: 10th Jan 2015, 15:36 -
Subtitle Edit command line problem,..
By Selur in forum SubtitleReplies: 2Last Post: 26th Oct 2012, 17:14 -
1 line subtitles on Subtitle Workshop
By Valerc in forum SubtitleReplies: 2Last Post: 15th Jun 2012, 18:28 -
add subtitle with mkv
By ali63 in forum SubtitleReplies: 0Last Post: 16th Dec 2011, 10:36
