I'm using a Hauppauge HD PVR Rocket to transfer some VHS.
Unfortunately there are plenty of times on VHS when you have gaps of static or just bad data, and this causes a loss of signal (video sync), which on a TV would just give you a temp blue screen, but the Hauppauge decides that means it should stop recording.
So I can't get through a whole tape without the Rocket detecting loss of sync and ending the recording early.
Does anyone know a trick here? Is there a way to get the Rocket to keep recording? Or is there a Composite adapter box that will just output a blue screen when input goes bad, therefore maintaining output sync?
You might try a different VCR or check your VCR menu settings if you have a higher end model. I know on my Panasonic there is a menu item that can be selected to blue screen static.
I have a Hauppauge HD PVR 2 but I get much better results from my Canopus DV firewire box, my old ATI PCI capture card, and my standalone DVD recorder.
I know some don't like the Canopus boxes since they capture in DV, but for really bad problem tapes they are very good at keeping the sound in sync.Last edited by Vidd; 15th Sep 2016 at 16:41.
So I'm still having trouble with capturing VHS. Some segments of tape get a little wonky. Watching these segments on a TV aren't a problem because you still get the gist of whats going on. But my capture device always "loses signal" during those segments.
Does anyone know of a pass-thru composite stabilizer that will output a valid video sync while still showing, as best it can, what the input is? -
Can't capture signal from JVC HR-S9911U VHS deck into Hauppage capture card
By vhscapture in forum Capturing and VCRReplies: 3Last Post: 18th Jul 2016, 13:07 -
Composite digital signal into laptop: can't find signal stream on laptop!!
By herder in forum Capturing and VCRReplies: 19Last Post: 17th Jul 2016, 15:11 -
Capturing TV signal with Hauppauge HD PVR (via composite)
By alexvsc in forum Capturing and VCRReplies: 21Last Post: 13th Mar 2014, 13:37 -
s-vhs vs composite
By Tafflad in forum RestorationReplies: 25Last Post: 9th Sep 2013, 17:34 -
SDI, Component(Y), Composite in PAL signal
By luckyo in forum Capturing and VCRReplies: 0Last Post: 18th Jun 2012, 08:22
