Hello to all.
This is my first post and would welcome gratefully any help.
Extracted audio file from divx movie using Virtualdub to create wav file.
Started TMPGenc and encoded the divx movie avi with the wav file I extracted with Virtualdub.
Visually the resulting mpeg is very good.
Problem is the audio is out of sync.The sound is infront (only very briefly) of the actors/actresses lips moving.
Please advise and thankyou. :cry:
Guest
yea that happen to me too. The audio was out of sync, and in sync at times. When you save the wav with virturaldub. You should open the wav with winamp to uncompress it. or in virtural dub goto full processing mode, goto compression and change it to PCM (uncompress). But when I had this problem, I switched to the Panasonic Mpeg1 encoder, I read a guide that told me to uncompress the wav with winamp. I'm sure it will work with tmpg but I haven't tried, if it continues to be out of sync then you should try the Panasonic Mpeg1 encoder. Because it worked great when i use a seperate video and audio source
is the audio you are using maybe 48khz? I think it needs to be 44.1khzOriginally Posted by Ryu_hoshi
instead of using winamp, in virtualdub, audio->full processing mode, no compression(PCM) file->save wav
use this wav as audio source.
I would recommend encoding video only, using besweet or something for audio separately and multiplex the 2 files in TMPG or BBMPEG
besweet gui is nice bcz it can downsample 48-44.1khz and convert to .mp2 all at once for you, using good tools(SSRC,2lame...)
VirtualDub won't open divx movie
By shmish in forum Video ConversionReplies: 9Last Post: 15th Mar 2010, 08:54 -
Burned my first divx using Nero but they are not in sync
By Taylor in forum Newbie / General discussionsReplies: 6Last Post: 4th Sep 2007, 00:07 -
audio not sync with virtualdub :(
By N3kr0 in forum EditingReplies: 0Last Post: 21st Jul 2007, 13:07 -
Virtualdub and audio sync
By Roy47 in forum Video ConversionReplies: 1Last Post: 30th May 2007, 08:57 -
VirtualDub unable to keep audio sync'd on *source* audio
By falconne in forum Newbie / General discussionsReplies: 1Last Post: 29th May 2007, 07:12
