Hello,
I have a DVD without subtitles : Train to Pakistan. So, I downloaded subs, but found only Russian ones. And they are written in cyrillic characters...
I am completely lost. How can I translate the subs to add them to my DVD?
Spassiba!
Load in Subtitle Edit and click "Auto-translate" at the top (if image based subtitles you need to OCR first). But with all auto-translations the result will be horrible so I suggest you keep searching for a French or English subtitle or buy the DVD with English subtitle.
How to translate Cyrillic characters?
Hi sneaker,
thanks for your quick answer. Subtitle Edit was good (I had to import with manual chosen encoding, and choose Cyrillic). Then I made the translation, it worked perfectly!
Of course, there are some strange words, but now I can understand most of the movie.
If it is a good film, I'll buy the DVD. (thanks for the french link. I think I found cheaper here: http://cart.payments.ebay.fr/sc/add?srt=01000100000050510a2bc7d4c13abffcfc6b95a5b4a0a2...49692222,qty:1)
Hi El Heggunte,
thanks for this precision.
Have a nice day, both of you
Subtitle Processor - anyone know of guide to translate?
By dweeb52 in forum SubtitleReplies: 6Last Post: 15th Jan 2016, 09:27 -
how translate had subbed video
By ashymashy in forum SubtitleReplies: 5Last Post: 11th Feb 2014, 09:08 -
Translate DVD menu
By charlesn73z in forum Authoring (DVD)Replies: 5Last Post: 11th Dec 2013, 18:27 -
Reading a Windows Cyrillic file in Notepad or Wordpad - Subtitling Purposes
By devilcoelhodog in forum SubtitleReplies: 0Last Post: 30th Jun 2013, 12:35 -
How can I translate a frame number to bytes ?
By Randm_Task in forum EditingReplies: 1Last Post: 17th Mar 2013, 22:52
