Please help me if you can.
I have a DBPower 9.5" Portable DVD player.
It has been fine but the last two DVD's that I have purchased will not play.
They are the new Jungle Book, and Star Wars the Force Awakens. Both discs play fine on every other player I own.
DB Power sent me a replacement unit. Same problem. Wont play these latest discs.
The supplier suggests that they may be 'Professional or Dolby Discs' whatever that means. What do I know I just bought them from Tesco.
The Player was purchased in the UK via Amazon UK. The DVDs were also purchased in the UK.
Any ideas?
Regards
If they have sent you the latest player, with the latest firmware, there probably isn't much else you can do to the player. The other option is to decrypt and rip the movies to the hard drive of your computer and burn to new discs.
I have no idea what your supplier is talking about. Dolby sound (AC3) is included on the vast majority of commercial DVD's.
If you want to decrypt, rip and burn to new discs, you should try the free trial for AnyDVD or one of the free trials for DVDFab Passkey, or the main DVDFab program. If you want a complete copy, you can do this, but you would probably have to burn to double layer DVD's and the only ones we recommend are made by Verbatim. You can copy and compress to fit a single layer disc with the main DVDFab program. -
Not play right?
Audio or Video
I'm not aware of any changes in the mfg publishing of new commercial release DVDs
Aren't those both from Disney ?
You might check online, see if anybody else is having problems with Disney releasesLast edited by theewizard; 14th Sep 2016 at 12:58.
Playing films from SD card on Panasonic dmp b15 portable bluray player
By drlbluray in forum DVD & Blu-ray PlayersReplies: 2Last Post: 15th Jan 2014, 12:06 -
Portable DVD Player vs Portable Video Player
By DJboutit in forum Newbie / General discussionsReplies: 9Last Post: 2nd Dec 2012, 18:28 -
Portable DVD player trouble
By phk1967 in forum Newbie / General discussionsReplies: 0Last Post: 28th Oct 2012, 15:30 -
What can I do with a nonloading portable dvd player?
By yoda313 in forum Portable VideoReplies: 11Last Post: 3rd Apr 2012, 16:04 -
Looking for a portable dvd Player or similar device.
By AntCoe in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Oct 2011, 16:54
