Results 1 to 9 of 9
  1. Member whitaker's Avatar
    Sep 2016
    Wichita
    Greetings.
    I am using Microsoft outlook 2003. I have created one pst file. Now i can not open it because get the following error: pst is not a personal folder
    Does anyone have an idea as to what may be causing this?
    How to make microsoft outlook 2003 fix ?
    Regards,
    Kelly
    Oct 2005
    666th portal
    run outlook click file open and choose the pst. if outlook can't open it, it's probably screwed up.
  3. Member whitaker's Avatar
    Sep 2016
    Wichita
    Unfortunaly it's screwed up.
    Thanks for help anyway
  4. https://support.microsoft.com/en-us/kb/272227
    And my humble advise - next time after making backup verify if it's done correctly.
  5. Member Cornucopia's Avatar
    Outlook usually comes with a pst/ost file repair utility. Run it through that and see what happens.
  6. Member whitaker's Avatar
    Sep 2016
    Wichita
    pandy thanks for advice
    Cornucopia what utility do mean?
  7. Member Cornucopia's Avatar
    Same utility mentioned in pandy's link: scanpst.exe (i just didn't fully trace down & read through the link before posting). Comes with every install of outlook since at least 2000 til now.
    If that doesn't work, you are SOL (unless you've got $$$ to burn).
  8. Hello Kelly.
    Use scanpst.exe to check the pst file for errors. The location of scanpst.exe depends on your version of Outlook and Windows. When scanpst.exe is unable to fix it there might have been some serious corruption in the pst file. There are some recovery softwares available like Outlook Fix Toolbox https://www.fixtoolbox.com/outlookfix.html
    I hope it helps.
    Good luck,
    Jack
  9. Member whitaker's Avatar
    Sep 2016
    Wichita
    Cornucopia ,jackchase
    Thanks for your help.
